Coolng system
Old Sep 7, 2002 | 12:38 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Coolng system
I purchased an coolflex upper radiator hose kit (chrome) for my vette...
also an chrome 15lb. radiator cap....the one on the car now is 16lb.
will the 15l. be OK????
Come on you guys are so shard out there...what do you think.....what if I put on a flowcooler water pump....what cap should I run then???
tony
oldace1@earthlink.net :smash:
Old Sep 7, 2002 | 09:44 AM
halver's Avatar
halver
Default Re: Coolng system (oldace84)
got a picture of your hose kit, where did you buy it? hbver@***.net
hal in san diego :cool:
Old Sep 7, 2002 | 10:58 AM
don hall's Avatar
don hall
16lbs to 15lbs - you will be just fine. A pressurized cooling system increases the boiling point of the fluid. You and the vette won't notice the difference. There will a tad less pressure on your coolant components; coolant will flow into the overflow bottle a tad sooner. No biggie! Run the same cap with the flowcooler pump.
Old Sep 9, 2002 | 12:10 PM
oldace84's Avatar
oldace84
Default Re: Coolng system (halver)
I ordered it from http://www.coolflex.com...
Cost for complete upper hose kit was $158.59...for the '84 I ordered the
36" kit in chrome....
Hope this helps...
tony :smash: :chevy
To Coolng system
