700R4 Governor questions
Old May 15, 2016 | 02:13 PM
Rcdizy's Avatar
Rcdizy
Default 700R4 Governor questions
https://www.corvetteforum.com/forums...or-change.html
This is in a C3 corvette.
Old May 15, 2016 | 05:04 PM
Aardwolf's Avatar
Aardwolf
I changed mine and adjusted weights when I changed intakes. It's not that bad until you have to adjust it many times. I don't remember it leaking any ATF. I didn't think reinstalling the cover was any big deal. Especially if you pick up a C clip that holds it on. Mine did not have one stock.
I bought a new gov advertised at the RPM I wanted but it wasn't close. I bought the B&M gov recal kit and changed the weights. Having two govs was nice for this process.
Old May 15, 2016 | 09:59 PM
Vic'89's Avatar
Vic'89
Originally Posted by bow tie guy
if it shifts too early and too soft adjust the TV cable
California performance transmmision has a tutorial, and so does bow tie overdrives
The proper way to adjust shifts points is via the governor.
Vic
Old May 16, 2016 | 01:48 AM
Cliff Harris's Avatar
Cliff Harris
Earlier covers used the clip and an O-ring seal. Later covers are press fit. Obviously the earlier covers are preferred if you're going to take it off multiple times.
To 700R4 Governor questions
