vats sometimes fails
Old Sep 7, 2002 | 05:47 AM
ringleader90's Avatar
ringleader90
Default vats sometimes fails
last few months put the key in, nothing... car won't start, wait 5 minutes and it starts. Thinking of buying vats bypass from mid america. any other ideas besides installing new ignition switch and new keys?
Old Sep 7, 2002 | 12:04 PM
jfb's Avatar
jfb
Default Re: vats sometimes fails (ringleader90)
So what is wrong with keeping your C4 in good repair? If a headlight burns out do you epoxy a flashlight to the hood? I drive my 87 vette every day and I'm on ign sw #3 for the VATS contacts problem. 99% of cars are stolen by bashing the column and jumping the ignition. VATS prevents these thefts. You can prove its VATS when it won't start by unplugging the 2 pin connector on the wires from the steering column (on my 87 they are under the carpet by the steering column) and measuring the resistance with the key in. The resistance should be the same as the pellet. If not, its the ign sw contacts. You can temporarily defeat VATS until you can get the ign sw replaced by clipping a fixed resistor the same value as the pellet onto the wires that go over to the passenger side (VATS module).
Old Sep 7, 2002 | 01:45 PM
ringleader90
Default Re: vats sometimes fails (jfb)
Thank you for your info, much appreciated
[Modified by ringleader90, 5:46 PM 9/7/2002]
Old Sep 7, 2002 | 02:37 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Try cleaning both sides of the pellet in the ignition key with alcohol. Take a Q tip and do the same in the lock itself. A little grime can change the resistance numbers and trigger VATS.
To vats sometimes fails
