Aluminium plug wire seperators
Old May 17, 2016 | 01:21 AM
Bendeco's Avatar
Bendeco
Default Aluminium plug wire seperators
I like the look of the aluminium plug wire seperators but will the metal cause any problems with the wires? I have 10mm plug wires.
Old May 17, 2016 | 05:45 AM
hcbph's Avatar
hcbph
Put these on my 86 earlier this year, so far no issues
Old May 17, 2016 | 09:04 AM
Churchkey's Avatar
Churchkey
Use zip ties.
https://www.google.com/search?q=zip+...jmJGpLsddEM%3A
Old May 17, 2016 | 02:59 PM
Bendeco's Avatar
Bendeco
Zip ties might be to trailer park. I think I will order some black aluminum ones from eBay. My wires are red so black will look the best I think.
Old May 17, 2016 | 03:13 PM
Bendeco's Avatar
Bendeco
Default Valve cover gaskets which ones don't leak?
Which valve cover gasket to buy? Which ones don't leak or less likely to leak?
Last edited by Bendeco; May 17, 2016 at 03:36 PM. Reason: I put it in the wrong spot
Old May 19, 2016 | 09:50 AM
jimmers's Avatar
jimmers
I routed mine using Moroso brackets. I love them. Keeps the plug wires away from touching the valve covers and it gives for a clean look.
Old May 19, 2016 | 10:17 AM
BOOT77's Avatar
BOOT77
They make plastic ones like those red, just can't let them get too close to the exhaust heat or they warp and come off. I like the plastic separators with zipties to hold them in places so I can just quick cut them loose and take the cover off faster.
To Aluminium plug wire seperators
