4+3 Tranny UGGGHh
Old Sep 7, 2002 | 01:41 PM
tarheelracer's Avatar
tarheelracer
Default 4+3 Tranny UGGGHh
Ok, boys,
I drove today about a 1 hour round trip to NC State, and on the way back, I'm in downtown Chapel Hill and I start to see smoke coming out from under my car. I make it back to my dorm and sure enough there's tranny fluid sprayed all over the passenger side of my exhaust system, right around the OD unit. The fluid was red so I knew it was ATF. Is there an overflow outlet or anything right there or does that sound like a busted seal. I'm hoping that maybe it just had too much fluid in there and it hasn't really ever gotten heated up and it was just releasing. Tranny was working fine. I'm gonna be ticked if this is major.
[Modified by tarheelracer, 5:41 PM 9/7/2002]
Old Sep 7, 2002 | 05:52 PM
Rich B.'s Avatar
Rich B.
Default Re: 4+3 Tranny UGGGHh (tarheelracer)
I'm gonna be ticked if this is major...
Is there a *minor* repair on a Vette??? :rolleyes:
There's a 90* vent on the top rear of the OD, I can't even see mine, but there is supposed to be a hose going up towards the engine compartment. Doesn't do anything, unless it comes off, then I suppose it *could* leak fluid out...Maybe if it was to suddenly pressurize...
More likely one of the steel lines going to the radiator has a leak...And is spraying out...
Old Sep 7, 2002 | 05:54 PM
darkcarn85's Avatar
darkcarn85
The is an overflow outlet on the driver's side. One of the geniuses working on my car left it off once. When I went up a steep hill it looked like a fog machine in my rear view mirror. Some just have a pop off valve others have a tube leading to the engine compartment. Be patient and sort the thing out. They 4+3's really are worth the hassle. Just ask Scorp! :seeya
Old Sep 7, 2002 | 06:08 PM
scorp508's Avatar
scorp508
You should have a breather tube on your overdrive that runs up into the engien compartment near where the engine harness plugs into the firewall. It is just a vent at the other end of it. Where it attaches to the OD is simple a pressure fit, usually they have some RTV around them to hold them in.
Old Sep 7, 2002 | 06:17 PM
Rich B.'s Avatar
Rich B.
Default Re: (scorp508)
Where it attaches to the OD...
Scorp -
Do you know if *any* of the line fittings on the OD have o-rings on them??? The short one in your pic, or the ones going to the radiator???
Old Sep 7, 2002 | 06:19 PM
scorp508's Avatar
scorp508
Default Re: (Rich B.)
For the breather or the fluid? The fluid lines do not, nor do the breather connections to the OD and 4-speed. At least I have not seen any one both of these trannies.
Old Sep 7, 2002 | 08:12 PM
tarheelracer
I'm really in no position to anything for my car right now. I guess I have no choice but to take it to a service shop to get them to check it out. :(
Old Sep 7, 2002 | 08:55 PM
VetteRacer282's Avatar
VetteRacer282
Scorp: Where did that clean tranny come from?
Matt
Old Sep 7, 2002 | 08:58 PM
scorp508's Avatar
scorp508
I bought it off ebay months ago when I needed another one. $400 for the complete unit. :eek:
Old Sep 7, 2002 | 09:24 PM
Rich B.'s Avatar
Rich B.
Default Re: (tarheelracer)
Does it spray only when you get moving???
I'd look at those steel lines...
Old Sep 7, 2002 | 09:26 PM
scorp508's Avatar
scorp508
Definitely make sure those lines are tight. That is how I burned up my 2nd OD unit as the top line wasn't tight enough and it leaked fluid. :(
Old Sep 7, 2002 | 09:32 PM
Rich B.'s Avatar
Rich B.
There's only hydraulic pressure when the car is moving, right??? So if the car is running but not moving, there should be no spraying, like from a bad seal/o-ring/gasket...
I'd think you'd have to be really sliding the car around to sling fluid out the breather/vent...
And those steel lines are on the side with fluid traces...
Old Sep 7, 2002 | 09:33 PM
scorp508's Avatar
scorp508
Correctomundo. The pump is driven by the output shaft if I understand the setup right.
Old Sep 8, 2002 | 01:51 AM
tarheelracer
So the "too much tranny fluid that heated up and overflowed solution" is out of the question so this is my plan. I have to take my car back to my parking space tomorrow so I don't get towed, then my sister is dating the head mechanic at the Honda place in town so I'm gonna "borrow" his lift and hopefully find something easy to fix if that's possible. I have to drive it about 15 more miles total so I hope i've got more left in this thing.
[Modified by tarheelracer, 5:55 AM 9/8/2002]
Old Sep 8, 2002 | 02:38 AM
jmr302's Avatar
jmr302
There is an o-ring underneath the aluminum block that that one tranny cooling lines attaches to. Odds of that coming loose are probably slim but maybe if the OD was recently replaced/removed...
You'll have to click here until I learn how to post pics! :bb
EDIT: Just a little misunderstanding concerning the use of the "[IMG]" command. Here we go:
[Modified by jmr302, 10:55 AM 9/9/2002]
Old Sep 8, 2002 | 10:45 AM
Rich B.'s Avatar
Rich B.
Default Re: (jmr302)
I was thinking the o-ring may have dried out and broken...Like all the o-rings in my Purox torch do every Winter...
(You have to open a Home Page on CorvetteForum and post pics to that; then link it to the thread)...
Old Sep 8, 2002 | 11:10 AM
tarheelracer
That o-ring coming loose is very possible because that is pretty much where the leak is at. Thanks for all of the help fellas.
To 4+3 Tranny UGGGHh
Old Sep 8, 2002 | 11:25 AM
scorp508's Avatar
scorp508
Ahh ok. I've never taken that aluminum block off, didn't know there was an o-ring there.
Old Sep 8, 2002 | 12:56 PM
Rich B.'s Avatar
Rich B.
...I ... didn't know...
...(Gasp!)... :eek: :eek: :eek:
Old Sep 9, 2002 | 01:14 AM
Duntov85's Avatar
Duntov85
I wouldn't drive that car anywhere unless you want to have the tranny rebuilt. Get it towed. It might be fixable at this point.
There are several o-rings and fitting on the right side of the tranny. You got to get under there and look.
The "aluminum block" you all are talking about actually houses a pressure relief valve for the tranny cooler. Line pressure must be about 70 psi to run fluid to the cooler, if I recall. I'm not reading the service manual right now. There's about 4 o-rings on that side of the tranny and several pressure fittings. You just need to get under there and look. I hope you get lucky. Otherwise $$$$
