Hi, Guys need to know how to open my hood on a 1984 vette.... I played with cable adjustment on the driver side.. didn't really need to but got myself in a jam.. the passenger side release's driver side don't now.. need help.. thanks for your time
Try driveing it up on a curb or a speed bump differant ways to flex it. Then put emergency release cables on it. Or you can get some 3/8 round stock and make a release tool look on youtube to see how to use.
Use the release at the same time It depends on how bad you screwed it up.
I agree give the car a little flex you can do the same thing with a jack, just be careful you don't want to pop the hood cable on either end and make a nucence problem a real one
Question did you just loosen the cable a few trying to get a little more bite on the latch,and it's now not clearing the pin
Still waiting to see your fix. Are you still whistling down the road?
Ha ha ha, whistling? kind of, didn't mount them yet, got preoccupied with work, and recently the starter replacement was needed due to it running with the ignition off, almost burned out the battery cables.
Had to replace some wiring, and of course the starter with a reman unit.
Cars running better than before.
Will probably finish this project within the next 2 weeks then post pics.
Thanks antfarmer2.... I see what you mean about the curb ... I tried to release and pull up at the same time.. nothing.. the other side I can pull up but its tight... thanks for your time
My hood is slightly out of adjustment, and havent taken the time to fix. I use a bungee to hold the release handle open, then I pull on the hood on each corner which lets it pop free.
This only works if its out of adjustment in that direction.
Try using a pair of vice grips to hold the steel hood release cable in the open position, then yank on the hood, this may free it.
Also try jacking up the car on the drivers side and then pull on the hood.
If it still won't open, lower the drivers side, and jack up the passenger side and yank on the drivers side again.
If this fails try the special tool first, i made my own, found it useless after an hour trying to get it open and opted obviously for the easier route. The reason being that the hood cable did release, but the pin was jammed.
If you do get it open, check your hood to make sure it's not loose, there are bolts that hold it at the bottom front, if they get loose the hood will shift enough to jam the pin against the receiver in the mount.
I have that tool pictured and have used it a few times (don't ask why). If you live anywhere near me, we can open that hood. I live near the drag strip in Indianapolis, Indiana.
