TDC help?
Old May 20, 2016 | 08:08 PM
dgantt's Avatar
dgantt
Default TDC help?
I bought a TDC tool, the kind that goes in the #1 cylinder. You then rotate the engine clockwise (by hand) until it stops and mark the HB at 0 degrees and then rotate the engine counter clockwise until it stops and mark the HB at 0 degrees. You the split the difference between the two marks and you have your true TDC. Problem I'm having is when I rotate the engine counter clockwise the bolt on the HB loosens and the engine does not rotate. Any one done this before? Is there another way to rotate the engine counter clockwise? Thanks for the advice.
Old May 20, 2016 | 08:12 PM
69mako's Avatar
69mako
Which bolt loosens up...the main center bolt? You can also turn the crank by one of the three outside bolts.
Old May 20, 2016 | 08:17 PM
dgantt's Avatar
dgantt
yes sir the main center blot.
Old May 20, 2016 | 08:30 PM
s carter's Avatar
s carter
since you probably need the space you probably already have the pulley off already you could protect the threads of pulley bolts or find to use bolts and use them as a leverage point with a long screwdriver between them to rotate the motor
Old May 20, 2016 | 08:43 PM
dgantt's Avatar
dgantt
Pulley is still on there it rotated with not issues clockwise. How big of a pain is it to pull the off, not much room down there. Do you need a HB removal tool?
Old May 20, 2016 | 08:58 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Pull the starter or the flywheel inspection cover, turn engine w/a screw driver or pry bar in the flywheel teeth. Shorten the distance required by going past TDC a bit, screw in your tool, back then engine/piston into the tool...then rotate forward w/a wrench until the piston hits the tool again, on the "other side".
Old May 20, 2016 | 09:03 PM
s carter's Avatar
s carter
Center bolt already will loosen as you said just remove the other 3 and shake the balancer will remain behind reinstall the center bolt for a just in case balancer tries to wander but I doubt it would, besides that's what your marking up.
You never did say what motor or year? it makes a deference, 84 thru the L-98 have a stamped steel pulley but the LT-1's ushered in the pulley/balancer as 1 unit
Old May 20, 2016 | 09:29 PM
antfarmer2's Avatar
antfarmer2
If it is a lt1 just take the three bolts off leaving the center one in. Then get under the car and smack the inside of the pully with a brass drift or one by turning as you go till your arm falls off. Pully will come off shortly after.
Old May 20, 2016 | 11:00 PM
dgantt's Avatar
dgantt
Sorry L98. So just take the 4 bolts out and shake it back and forth until it comes off? Looks like a new one is only 50 bucks might as well replace it.
Old May 20, 2016 | 11:15 PM
s carter's Avatar
s carter
Shake will get the pulley but not the balancer, to get the balancer off that will take a puller there not expensive and usually can get from loan a tool at the part store
If you do get a new balancer or remove the old one for so reason you may want to also look for the balancer installer tool some may say tap on with hammer and seat with center bolt I'm not a big fan of that a tool for every job.
Old May 20, 2016 | 11:39 PM
dgantt's Avatar
dgantt
Thanks for all the input ya'll. What I really need it to be able to do is rotate the engine back wards to use the TDC tool. Maybe if I take off the pulley I can put the bolts bake in and use a large screw driver to put in between two bolts and twist counter clockwise. I have the spark plugs out so there shouldn't be much resistance. Is there any thing I need to worry about rotating the engine backwards, I don't think that will be a issue.
Old May 21, 2016 | 12:00 AM
s carter's Avatar
s carter
Yup stick with the mission replace the balancer only if you think there's problem so leave it alone and find your TDC
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Someone posted a pretty easy way to do it;
Old May 21, 2016 | 08:44 AM
s carter's Avatar
s carter
That is also a good way but I thought up a much easier way, find a large strap wrench l have a real long one for changing home water filters that would make it around the balancer or pulley
Old May 21, 2016 | 09:08 AM
dgantt's Avatar
dgantt
Strap wrench, I like it. Since I'm only going 360 degrees back ward all the spark plugs are out so couldn't I just grab the belt right off the HB and pull it counter clockwise. The tension should move it. It may slip a time or two but it doesn't have to go far. I have seen some one do this but pulled it clock wise, he was in a pinch with no tools. It worked, he pulled the serpentine belt clockwise until the he hit 0 degrees.
Old May 21, 2016 | 10:51 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Strap wrench IS a great idea.
Still, OP, you don't have to go 360* backward. Only a few degrees, if you do it the way that I described.
Old May 21, 2016 | 12:38 PM
89onlyZ51's Avatar
89onlyZ51
Don't use a strap wrench on the balancer our you risk shipping it's outer ring.
To TDC help?
Old May 24, 2016 | 05:14 PM
tuned's Avatar
tuned
The easiest way for TDC depends on what ur going to repair on the engine. I myself had a head gasket failure and I planned on a much needed timing chain. So, take off the distributor cap. Point the rotor exactly at #1 cylinder located by reference on the distributor cap. I'm talking about a tuned port. I haven't done this on an lt1,so I don't know if it would work or not. But there is no need for a TDC tool if u know ur gonna do the timing chain anyhow because if ur timing chain is as slack as mine. TDC is gonna be wrong unless u use the TDC piston tool. I mean mine is real loosey,goosey!!!!
Old May 24, 2016 | 11:11 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If you read the thread...you'd have seen that the OP is using a TDC/piston stop tool.
Old Jun 11, 2016 | 02:57 PM
tuned's Avatar
tuned
Default Why do u have to use a TDC tool?
Why would not just point the rotor to #1 and be done?
