Stranded - Just happened
Old May 31, 2016 | 04:10 AM
DaveP85C4's Avatar
DaveP85C4
Originally Posted by Big Bird 88
RWDsmoke,
Security light went out when I put the key in and turned the ignition on. That's tells me no VATS.
Nope. You're incorrect.
2 things:
The security light is not associated with VATS in a C4 Corvette. The security light only indicates status of the entry alarm system. Security light has nothing to do with VATS. VATS and the alarm system are separate. Nothing in common.
Even if the VATS key pellet has been bypassed, the starter enable relay still has to make contact or it won't crank. The relay is a big deal in every early VATS GM car. They go bad, and it won't crank.
Check the ECM for codes. If there is a 46, this is set by a VATS problem. If there is no 46, replace the relay. It is behind the DIC or the radio. I don't remember which. On the RH side of the cavity, on a bracket, look for 2 large gauge yellow wires, and 2 green wires. Those are the colors for the relay.
Old May 31, 2016 | 10:01 AM
Big Bird 88's Avatar
Big Bird 88
Dave, thanks for your input but it's contrary to what I have seen myself and read. Yes I understand the bypass isn't truly a bypass, I think only sure way is to pull the chip and erase VATS.
No code on the ECM
Old May 31, 2016 | 10:19 AM
PatternDayTrader's Avatar
PatternDayTrader
I thought the security light received battery voltage from the gauges fuse and the VATS module grounded the light depending on the status of the system ??
Maybe someone will post a schematic.
Old May 31, 2016 | 10:20 AM
WVZR-1's Avatar
WVZR-1
No code on the ECM
What you've read is likely Internet "LORE" - observed? I don't follow. I think you mentioned having the FSM so I'd get to the 8A-133-0 and "study" THEN the 8A-133-8 and "study". Learn your vehicle's THEFT and VATS functions -- It's all there!!!
There's also a "NO CRANK" in drive-ability. Dave's suggested "Starter Enable Relay" is the first to check I'd think. '88 was the first year for the compact starter and it might not be odd to have issues in the starter proper with contacts that can be serviced. Heat soak on a 'denso yes but not as likely as the older Remy.
Old May 31, 2016 | 10:34 AM
DaveP85C4's Avatar
DaveP85C4
Originally Posted by Amotoxracer
I Maybe someone will post a schematic.
Note in my post I described the wire colors into the relay, and the location of the relay. You think I pulled that out of my azz? No. I got it from the FSM's I bought for a car I sold 18 years ago. I never had trouble with the VATS in my 88 and it was functional, I remember "testing it" because I was curious if it worked or not. It did.
I did look at the schematics for both systems to refresh my recollection prior to posting.
I know that isn't good enough for you guys. Neither is experience with 100's of C4 Corvettes. Nor having owned an 88, which is the subject car. I know you're OK with peeps posting "basics", even if it's wrong or inaccurate, but I don't do that. You can believe it works the way you think it works and never fix your car, nor will anybody else if you provide incorrect, or inaccurate information. But I really don't care.
The security light has nothing to do with the VATS system.
Old May 31, 2016 | 10:42 AM
PatternDayTrader
I did look at the schematics for both systems to refresh my recollection prior to posting. .
I know that isn't good enough for you guys. Neither is experience with 100's of C4 Corvettes. Nor having owned an 88, which is the subject car. I know you're OK with peeps posting "basics", even if it's wrong or inaccurate, but I don't do that. You can believe it works the way you think it works and never fix your car. I really don't care.
Well that's great news (for you) that you have those resources available. Not everyone does. Perhaps you could be helpful and post the schematics ?? Or maybe that's too much work and condescension is your version of help ??
Old May 31, 2016 | 10:55 AM
DaveP85C4's Avatar
DaveP85C4
No code on the ECM
Cool. Think what you want. Your understanding of what the security light indicates in your 88 is incorrect. You're going to have difficulty fixing your car following an understanding of the system that is incorrect.
Now.
Technically, you DON'T have a VATS issue, because you don't have a Code 46.
The VATS module has 2 outputs: The "Fuel Enable" output to the ECM to allow fuel injectors to function. AND it grounds the Starter Enable relay coil. The other side of the relay coil is energized in START. So to close the relay, the VATS module must be grounding the relay. It probably is, because you don't have a Code 46. The contacts in the relay pass the current from the key switch through them to the clutch or Neutral switch and on to the starter. The full solenoid current passes through the relay, so it is reasonable to expect it to have a service life. The relay contacts are switching the current every time you crank the engine.
Replace the Starter Enable Relay. This is a very common failure in F-Cars, and the C5. One peep in this thread mentioned he had trouble with the relay as well.
Old May 31, 2016 | 11:05 AM
PatternDayTrader
There's a strange paradox at work here. On one hand your adamant about posting the correct details about the system in question, and you have admitted you have the correct resource materials, but then you wont actually post the schematic or a flow chart or anything else that would actually be helpful....
Maybe its no paradox at all. Maybe your just trying to fluffer up your ego by using the forum to prove (to yourself) that you possess some sort of technical superiority over those without the same resources.
Yes ... that makes perfect sense.
We do agree on something tho (as evidenced by your quoted post above), you really don't care....
Old May 31, 2016 | 11:25 AM
DaveP85C4's Avatar
DaveP85C4
A: It is illegal, and against most Forums' Terms of Use Agreement to post copyrighted material without permission. I will sometimes do it, but I attribute the source.
B: I am adamant about posting the correct details, because of only one reason. When I respond to a post, my primary reason for doing so is to re-learn it myself. I conduct the research, do the Google, get out the FSM, and by doing so I relearn or refresh my understanding of a particular system that I may not have had my hands on for decades.
In this thread, when I saw the OP's "the security light goes out so the VATS is OK" I thought "that's true in a VATS II System, but the C4 is not VATS II". I know that in the 88 (and all C4's) the security light indicates entry alarm status. (Few peeps seem to understand what it actually means though). I didn't recall an association of VATS with the Security light. So I got out the FSM's, and read the schematics for BOTH systems. There is nothing in common with the two systems.
Again: I do this for my OWN education. If someone else learns something too, or even fixes their car, great. But that is not my primary goal.
Even this post furthered my personal education. If you learned something too, great.
Old May 31, 2016 | 11:39 AM
PatternDayTrader
That's certainly fair enough.
Just keep in mind that you just showed up here and there are folks that have been contributing for many years. It would be a shame if some of those folks took offense to the way you deliver your message and decided to leave. It really would.
Stick around long enough and you will find there are plenty of folks who deserve to actually be abused, and when those times come around I will be with you every step of the way.
Old May 31, 2016 | 01:02 PM
Big Bird 88
Dave,
Sorry if I pissed you off, certainly did not mean this thread to take a turn like it did.
I will keep the VATS starter relay in mind. Has not happened since.
My experience with VATS and the security light when I was having VATS issues was
when I opened the door the security light lit. Then when I put the key in the ignition and turned to on, if the security light stayed on, the vehicle was NOT going to start. When I turned the ignition to on and the security light went out, it would start.
Light still behaves the same with the VATS bypass but now it always(or at least always since the bypass was installed) goes out when the key is turned.
I am learning these cars are never truly fixed, its just something else marked off the list.
when you pull a cover or look under anything it looks like 10lbs of crap in a 5lb bag, truly amazing ;-)
Old May 31, 2016 | 01:47 PM
vetteLT193's Avatar
vetteLT193
This is not true for all C4's but I think it is true for 1988. At some point they changed it and the Security light is used to indicate VATS. It is 100 percent for sure tied to both the door and Pass Key by 1993, as indicated in the owner's guide. If the VATS system doesn't have a valid key the security light will remain on after the key is inserted and will not allow the starter or fuel pump to function for 3 minutes.
Old Jun 1, 2016 | 01:49 AM
  #33
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
If all your starter/battery cables are snug and clean might look towards a hot solenoid, its a start
Agreed, when my starter/solenoid started to go out the car wouldn't crank at all when the car would get really warm or hot - basic heat soak. I replaced it and the issue went away immediately.
Same symptoms as you, no codes either and after a cool down it would turn over fine
Old Jun 1, 2016 | 04:44 AM
  #34
exitwound's Avatar
exitwound
Happened to me too..
I fitted a new starter, but also added a length of cable directly to the solenoid then up and over the firewall and across to a starter button which is fitted on the brace above the battery on my '87. This allows me to operate the starter directly from the battery in the event of any problems.
If you look carefully at this old image, you'll see the green and yellow cable running across the firewall and the starter button atop the battery on the brace.
Old Jun 5, 2016 | 05:31 PM
  #35
Big Bird 88
Think it may have been the batter. It happened again Friday afternoon and then started 30 mins later. Friend had a load tester and it failed abysmally.
Battery was just over 1 yr old so it was replaced Saturday Free of charge. We'll see how it goes. Thanks all for the help !
