My car has been pinging lately or knocking, on acceleration and right when it shifts gears. Its an 84 auto car.
I know the egr isnt connected up, but it never did it before. My oil temp gets high, about 225 degrees while the engine is around 200 even.
But I think the first thing I should check is the knock sensor, if its easy enough.
Someone qouted me $60 to test it and said he used a voltmeter. I want to see if the engine is being controlled by it so I need a different test.
DMM`s I have, timing light I dont have. Any suggestions?
P.S. the car had a bad head gasket almost 2 years ago I think it was, might have been bad since I bought it a year before it got real bad. Blue Devil still working.
Reason: P.S.
....with the timing light pointed at the balancer.
I'd hook up the egr again. It doesn't hurt your power.
I had some spark knock issues last year, seems like the engine was lugging because the torque converter locks up in 2-3-4gears. I unplugged the ttc connector & the knock is mostly gone. I'm looking into a kit that locks up the converter only in 4th & at around 55mph.
Gas isn't what it used to be either.
I suppose you could test a Knock sensor with a DMM by seeing if it makes a minimal voltage or Resistance change when someone makes a Knock.
But honestly Timing lights are cheap enough new even cheaper at Garage Sales and thrift/Pawn shops. The test is very easy put the timing light on # 1 cylinder, Check the timing is correct (remember to disconnect the EST plug) if base timing is good. turn off car reconnect the EST plug. start car rev. motor observe the timing mark should move some, Than raise idle to about 1500 / 2000 RPMs hold steady there look at timing mark have someone tap on the Head Bolt above the Knock Sensor with a long socket extension and small hammer, timing should jump with the taps.
Thank you everyone. I can get a timing light I guess, but I havent checked timing on a car in so long and it was a `different` brand.
If I can find the timing marks I can do it. Should I get some chalk or a white crayon?
Anyone have a photo of where the knock sensor is?
The egr solenoid isnt hooked up wasnt when I got the car. One of the thin hard plastic lines snapped on it too. So this should all be corrected no doubt.
What bothers me is hearing four or 5 raps or knocks or whatever. Wouldnt the computer catch it before that many?
The tcc isnt hooked up on the car but hasnt hurt it in the three years I had it. It has a broken pigtail and no vss so I know it never worked since I bought it, and drove it home from Michigan to St Louis.
Just in front of the starter above a shield bolted to the oil pan rail. My car is an '86, so it might be different (knock sensor location is the same):
Not having the TCC connected will affect your gas mileage. You do need the VSS to make it work.
Not as much as those leaky o rings did though, but Im still working on things as I go with this car, at least it didnt get parted out.
Would you put new wiper blades on a car that had a broken windsheild ????
Seriously ...... forget about the knock sensor until your tcc is functioning properly. That's good advice even though it may not be the advice your looking for.
Yeah, he's been burning up his tranny for 3 years now. Excessive spark knock can ruin an engine in one day.
At no point did I get the impression this was an excessive amount of spark knock. If excessive is the correct description of the condition, then it won't be a knock sensor problem anyway.
