LT-1 valve cover vent ?
Old Jun 3, 2016 | 08:46 AM
C4vettrn's Avatar
C4vettrn
Default LT-1 valve cover vent ?
My custom bent OEM hose for the passenger side valve cover vent is dry rotted and in need of replacing. Is anyone using a filter for vent and plugging off the throttle body or does this system require a vacuum to function correctly?
Old Jun 3, 2016 | 08:49 AM
antfarmer2's Avatar
antfarmer2
I would just fix it right.
Old Jun 3, 2016 | 11:49 AM
Kevova's Avatar
Kevova
it doesn't need vacuum. It does need filtered air. IMO... You would be better to replace to the hose, because the vent attaches to side of valve cover and the injector cover goes on top of it.
Old Jun 4, 2016 | 12:50 PM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Here's another way ! Internal tube is also baffled.
Old Jun 4, 2016 | 06:32 PM
C4vettrn's Avatar
C4vettrn
Is that something you sell ? Why does it look like it is a quarter turn fitting ? Does the fitting take place of rubber grommet ?
THANKS!
Old Jun 5, 2016 | 08:44 AM
BlowerWorks
Supporting Vendor
Hi All !
I take a new oil fill cap (L98 or LTx) and bore it for the tube that comes with the vent kit from Joe's Racing. Then I press the tube into the oil fill cap. Then pop on the breather.
I don't know the price. Will have to gather all costs and then post. greg
Old Jun 5, 2016 | 11:38 PM
Cliff Harris's Avatar
Cliff Harris
Adding a breather will change the AFR.
Old Jun 6, 2016 | 08:09 AM
BlowerWorks
Supporting Vendor
How's that ???
To LT-1 valve cover vent ?
