1994 opti cap/rotor question
Old Jun 4, 2016 | 07:39 AM
mrodoc's Avatar
mrodoc
Default 1994 opti cap/rotor question
I have 48,000 miles. And yes, I did a search, no one has asked this. When I disassembled my opti the ring seal where the cap meets the opti body was dry, cracked and broke to pieces upon removal. This is the large O-ring that is like 5" diameter.Opti unit itself was dry, no moisture inside, contacts pretty bad, though. Rotor broke just taking screws out. Anyway...my new cap/rotor did not come with a that new rubber O-ring seal where the cap meets the outer opti opti body. It did come with a replacement the small rotor seal where the rotor meets opti body. I went online and none of the units offered come with this large 5" rubber o-ring seal. So I just used high temp RTV gasket maker since the old seal is not usable. I put a strip of RTV on mating surfaces, hand tightened new cap to opti, after an hour tightened the four screws. Now as an after thought, I'm wondering if there was a better way. Comments? What have others done? I don't want to repeat this job. Thanks Gary
Old Jun 4, 2016 | 08:46 AM
PatternDayTrader's Avatar
PatternDayTrader
Well the best way would have been to replace the o-ring, but if the parts arnt available then your probably stuck with what you did. I seem to remember my local hardware store having a way to make an oring, where you cut the material to length then glued the ends together. It didn't work very well but it might be better than rtv.
Old Jun 4, 2016 | 09:24 AM
dizwiz24's Avatar
dizwiz24
i think you did fine with high temp silicone rtv - assuming you completed encircled the mating surfaces
Old Jun 4, 2016 | 10:30 AM
antfarmer2's Avatar
antfarmer2
You forgot the locktight on the screws.
Old Jun 4, 2016 | 05:49 PM
mrodoc's Avatar
mrodoc
Thanks. I used blue locktight.
To 1994 opti cap/rotor question
