Ruff cold idle LT1 fixed
Old Jun 5, 2016 | 07:17 PM
jph46's Avatar
jph46
Default Ruff cold idle LT1 fixed
Hi guys....been hunting for a slight surge mostly when cold in drive at a stop. Found a couple of broken vacuum lines in the cruise control line behind the battery. No change.
The fix..unplugged the IAC connector to see if there was any change, idle went to 1500rpm and held steady. Stopped the engine plugged in connector and did a IAC reset.
Throttle pedal slightly open, started engine for 5 seconds, engine off for 10 seconds, restarted, bingo smooth as a babies bun. FSM did its magic once again.
93 LT1
Old Jun 6, 2016 | 04:47 PM
jph46's Avatar
jph46
Default Ruff idle fixed- not
93 LT1
Well after thinking I found my promblem, it's now back. I think it may be the IAC or the conector? I'll start another post.
Old Jun 9, 2016 | 10:18 AM
hcbph's Avatar
hcbph
I was having some idle and low rpm issues on my 86 and it kept coming back to the IAC though codes pointed elsewhere. I'd bought another IAC but hadn't replaced it yet and was checking again one day. I was irritated and happened to have a plastic faced hammer with me at the time. I gave the IAC 3 or 4 so-so raps with the hammer and low and behold the idle issues went away and have not returned. I've also spent some time cleaning grounds etc on the car what may have helped but no way to tell for sure.
In my case if it was cold out, start up and go a few blocks then it would barely run. I always nursed it home to the garage. After 5-15 minutes, restart and it would run perfect, did not get codes every time though the SES light would come on most of the times when it happened but went away once back in the garage. Didn't happen every time, but when it did it was painful. IIRC the code I got occasionally with the SES was 43, it indicated a ECM failure. Everything else seemed to check out, so wasn't sure that was truly the cause. It's been a long time since it last happened and hopefully will not come back.
Old Jun 9, 2016 | 10:30 AM
ovrebo1's Avatar
ovrebo1
93 LT1
I have a 92, so I'm sure the procedure isn't on the same page, but I'm going to ask anyways; what page and or section is the reset procedure?
Old Jun 10, 2016 | 05:30 PM
jph46's Avatar
jph46
That can be found on 6E3-C2-14-15. See reset IAC valve pintle position.
This is for a 93,, found under heading: IAC valve
Old Jun 10, 2016 | 05:33 PM
ovrebo1's Avatar
ovrebo1
Thank you
To Ruff cold idle LT1 fixed
