wth-- HELP-- Hatch wont open!
Old Sep 8, 2002 | 06:53 PM
Jsailor24's Avatar
Jsailor24
Default wth-- HELP-- Hatch wont open!
All of a sudden none of my hatch release switches release the switch. Whats the deal and how should I test it? This is weird. All worked fine 2 days ago, now not at all? HELP...
TIA :confused: :(
Old Sep 8, 2002 | 08:08 PM
bogus's Avatar
bogus
Default Re: wth-- HELP-- Hatch wont open! (Jsailor24)
thats a pain... cause you need the hatch open before you can test anything!!!!
sounds like the servo... however, check your fuses...
Old Sep 8, 2002 | 08:10 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: wth-- HELP-- Hatch wont open! (bogus)
Get a meter and check for power. I am sure that you will find a bad connection somewhere if the fuse is still good. Also be sure to wilggle the fuse. Sometimes there is a bad connection there.
:cheers:
Old Sep 8, 2002 | 08:17 PM
2UHONEY's Avatar
2UHONEY
On my '92, once the door courtesy lights switch went bad and the hatch release wouldnt work until that got fixed.
Old Sep 8, 2002 | 10:47 PM
mdm's Avatar
mdm
If your release is clicking but the window is not opening--open the gas lid and gentley pry up on the window---mine sticks all the time
Old Sep 9, 2002 | 04:17 AM
1991ZR1's Avatar
1991ZR1
Sometimes when I try to open the hatch on my 91, there is just a click and the hatch does not open. There is an emergency release cable under the cargo cover a little to the passenger side. After I get it open, it works ok again. I'm not sure if all years have this cable.
Old Sep 9, 2002 | 04:23 AM
paintdaddy's Avatar
paintdaddy
Default Re: wth-- HELP-- Hatch wont open! (1991ZR1)
Explain more in detail where this is ,I have that same problem sometimes.
:seeya
Old Sep 9, 2002 | 04:40 AM
1991ZR1's Avatar
1991ZR1
Default Re: wth-- HELP-- Hatch wont open! (paintdaddy)
It's inside the car at the back of the cargo area. With the cargo shade rolled up, you can reach in under the rolled up shade. It's close to the center of the cargo area. I think mine is a little right of the center.
By the way, it's a little hard to pull on so I keep a Leatherman's tool, which has pliers, in my car.
I also think the procedure is described in the owner's manual.
[Modified by 1991ZR1, 8:46 AM 9/9/2002]
Old Sep 9, 2002 | 03:28 PM
paintdaddy's Avatar
paintdaddy
Thanks for the info!! :seeya
Old Sep 9, 2002 | 05:45 PM
Jsailor24's Avatar
Jsailor24
looking at it closer the servo is getting a signal but not enough to open i guess. Im not sure i like the pry method so maybe ill look for the release handle. any idea what the real problem is or how to fix? :confused:
To wth-- HELP-- Hatch wont open!
