is there a horn relay?
Old Sep 8, 2002 | 07:15 PM
soundkillr's Avatar
soundkillr
Default is there a horn relay?
Is there a horn relay and where can it be found? I have a 91 I think my relay is bad, because my horns only work sometimes, and I am almost certain it is not the buttons. Niether of them work when this symptom comes about, but when the car has been sitting, the horns work exactly as they should, with little to no effort on either button, so I have almost ruled that out. If there is a relay where can it be found?
Old Sep 8, 2002 | 07:44 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: is there a horn relay? (soundkillr)
On an '88 Vette the horn relay is behind the center of the IP in the multi-use center.
Old Sep 8, 2002 | 07:45 PM
2UHONEY's Avatar
2UHONEY
Dont quote me on this, but I'm pretty sure it's located under the glove compartment, there's a plastic cover with (Ibelieve) 4 screws and a courtesy lamp, remove it and in there you'll see a string of relays, Headlights, fuel pump, alarm sys. Etc and I believe one of them is the horn relay
To is there a horn relay?
