Where's the outside temperature sensor?
Old Sep 8, 2002 | 07:41 PM
95AquaC4's Avatar
95AquaC4
Default Where's the outside temperature sensor?
:confused:
Old Sep 8, 2002 | 10:53 PM
gcrouse's Avatar
gcrouse
Default Re: Where's the outside temperature sensor? (95AquaC4)
Mine was on the inside of the forward top radiator shroud- right side. But you have the newer slanted radiator so I'm not sure. Should be obvious when you find it tho; it's a big thing like a 1" tube mounted at a 45* angle; about 3x3x1" overall. Good luck!
Old Sep 9, 2002 | 11:06 AM
Greg Johnson's Avatar
Greg Johnson
I am not sure on a '95. The '94 owners manual tells exactly where the sensor is.
Greg
Old Sep 9, 2002 | 11:26 AM
Red Dwarf's Avatar
Red Dwarf
Bottom right of radiator......................You'll be able to see it once you get the front up in the air. Rectangular shape with wire running to it.
[Modified by lou sylvestri, 7:33 AM 9/9/2002]
To Where's the outside temperature sensor?
