Beam Plates
Old Jun 8, 2016 | 09:06 AM
Bulldogger's Avatar
Bulldogger
Default Beam Plates
Okay have a set I am going to install this weekend. My question is I have the preset gauges for top and side measurements to the transmission tunnel. my question is, if the measurements are off how would you adjust the clearance for the C-beam up or down? The side measurement would be by pushing the C-beam left or right, but how would you correct for up or down? Thanks
Old Jun 8, 2016 | 12:26 PM
BOOT77's Avatar
BOOT77
From my memory they are pretty much a no-go-gauge, worry bout that if they don't fit.
Old Jun 8, 2016 | 12:38 PM
Goldcylon's Avatar
Goldcylon
That has been my experience as well
Old Jun 10, 2016 | 04:40 PM
dclafleur's Avatar
dclafleur
honestly it isn't going to give you a lot of options, the bolts aren't likely to go in/torque down if you aren't lined up.
Old Jun 11, 2016 | 03:20 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
They're just nut plates.
Remove the OEM nuts and install the plates.
Pretty straight forward..
To Beam Plates
