Receivers
Old Jun 8, 2016 | 09:35 PM
s carter's Avatar
s carter
Originally Posted by antfarmer2
If it is the vats the pump will not run try my test free and easy.
It tells volumes and it takes more time to walk to the car than to do the test
Old Jun 9, 2016 | 08:05 AM
Churchkey's Avatar
Churchkey
If the fuel injectors are original they tend to fail when hot. The FI system is not sequential it is "batch fire" = if one injector shorts none of them will work = no start when hot. The injectors may be heat soaking during hot engine shut down.
If the engine has any misfire, stumble etc when hot it is an indication that the injectors are failing.
Ohm test each injector when hot you should have 14.5 to 16.5 ohms. If any are out of spec leave them disconnected & try starting the engine. If it runs (with a miss fire) the disconnected injector(s) are the issue.
Old Jun 9, 2016 | 04:59 PM
hcbph's Avatar
hcbph
I may have missed something, are there any lights on the DIC when it fails to turn over? If it was VATs related, IIRC you'll have a security light on.
As far as another key, if you only have 1 get another one cut and insure the resistor value matches the one you have (Dealer cut one for a friend and the wrong blank was used).
Now if you can duplicate the issue on demand, I'd get a remote starter first. Drive or whatever the car to set it up for it failing. snap on the remote starter, then first confirm it won't turn over using the key then try the remote starter. If it turns over that way you've removed part of the various systems from the equation (like a bad battery or not).
Old Jun 10, 2016 | 11:05 AM
Bev&Johnny's Avatar
Bev&Johnny
Cruising
If it is the vats the pump will not run try my test fre e and easy.
The pump runs so not the vats..That's one out of the way..Thanks
Old Jun 10, 2016 | 11:59 AM
antfarmer2's Avatar
antfarmer2
Check and clean battery connections and grounds and load test the battery if it has a jump box behind the battery clean this too.
