Differential Oil Capacity?
Old Sep 8, 2002 | 11:16 PM
c4md's Avatar
c4md
Default Differential Oil Capacity?
How much oil does the rear end hold? Factory manual, owners manual and dealer all have different numbers. Dealer told me 2-23 oz plus 4 oz of additive. Some of the catalogs sell you 3-23 oz bottles plus the additive. Thanks ahead of time for the help.
Old Sep 8, 2002 | 11:30 PM
silver & red CE's Avatar
silver & red CE
Default Re: Differential Oil Capacity? (c4md)
I've changed the lube twice on my Dana 44, used less than 2 pints after emptying a bottle of additive into the case first.
Eric
Old Sep 8, 2002 | 11:38 PM
imaruby's Avatar
imaruby
What do you have?If its a danna 36 it takes about 1&1/2 qts.Also use a synthetic like redlines 75w90,it includes the additive. :yesnod:
Old Sep 8, 2002 | 11:42 PM
Bgreenard's Avatar
Bgreenard
Go Fast
Default Re: Differential Oil Capacity? (silver & red CE)
My 93 shop manual doesnt give a specific amount, it just says maintain fluid level flush with bottom of opening(filler plug hole)to no more than 1/4"below opening.
BG
Old Sep 9, 2002 | 04:49 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Differential Oil Capacity? (imaruby)
Even when using the Redline fluid, you should add the additive. Redline has their own bottle of additive too. I put Redline in the last time I changed mine and used their additive.
Old Sep 9, 2002 | 06:05 PM
JasonL's Avatar
JasonL
Default Re: Differential Oil Capacity? (Vette92)
It depends on which Redline you are using. Their 75W90NS requires the additive if you use it with a limited-slip. Their 75W90 does not, since it is basically 75W90NS plus the additive, around 5% by volume. Which of course may not be the correct ratio we need, however...
Old Sep 9, 2002 | 06:24 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Differential Oil Capacity? (JasonL)
I will look at what I have. I got it from LG Motorsports and they said I would need the additive with what they sold me.
To Differential Oil Capacity?
