new heads = blow by, HELP!
Old Jun 10, 2016 | 06:47 PM
dgantt's Avatar
dgantt
Default new heads = blow by, HELP!
Just got a new set AFR heads milled to 58cc and comp 1.6 RR installed and now I have extreme blow by. I had oil coming out of my oil tube until I put a valve cover vent/filter on the passenger side CCV and capped of the TB port. It is a 90 speed density so I don't have to worry about un metered air, I'm also running the FAST ez 2.0 system. When I remove the PCV after the engine warms up smoke pours out of the valve cover like a choo choo train. After the VC vent was installed no more oil coming out of the tube but smoke coming out of the new valve cover vent. This was not a problem before the heads, I did a compression check but found all cylinders were between 160 and 175 psi. Any clue what could be causing this?
Old Jun 10, 2016 | 09:33 PM
jv9999's Avatar
jv9999
The bottom end may not be up to the increased pressures from the new top end. Compression isn't the whole story when it comes to blow by. I'd do a leak down test and be thinking about rebuilding (or a new) short block. It's not an uncommon problem with tight high compression heads on an old block.
Old Jun 10, 2016 | 11:33 PM
dgantt's Avatar
dgantt
Crap, that's what I was afraid of, thanks jv999. What do you think of a 383 with an 52mm TB, ported plenum, ported edelbrock high flow runners and intake. Think it will flow enough for a 383? According to the bench flow sheet they flowed 243cfm on my AFR heads.
Old Jun 11, 2016 | 01:11 AM
DanielRicany's Avatar
DanielRicany
Are they the 180, 190, or 195 CC heads? The 195s are supposed to flow 286 CFM according the AFR. If you have the 195s, it will be enough for a 383 but your intake is holding you back. You'd be better off with a Miniram with a 383 and AFR heads.
Old Jun 11, 2016 | 04:54 PM
ghoastrider1's Avatar
ghoastrider1
Those high flow runners will need cleaning anyway. I had lots of flashing around the ports that edlebrock never cleaned up ( another member here said the same about his runners). Its a good product but just not finished like it should be.
Old Jun 11, 2016 | 06:08 PM
ex-x-fire's Avatar
ex-x-fire
Yep, its risky to put fresh heads on a tired short block.
Old Jun 12, 2016 | 01:51 PM
89onlyZ51's Avatar
89onlyZ51
Nah, that's BS. His CR didn't change and new heads don't all of a sudden push an older bottom end over the edge. I suspect a cylinder wasn't fully clean of debris (head gasket scrapings, carbon build-up from the quench area, etc.) when the new heads were installed and either the rings got jammed or the cylinder damaged. Could still show good compression but bad oil control.
Old Jun 12, 2016 | 06:23 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
LT1/4??
You need to notch the block for the oil drain
Old Jun 13, 2016 | 08:31 AM
C4vettrn's Avatar
C4vettrn
Originally Posted by BrianCunningham
LT1/4??
Is this an AFR head thing?
Old Jun 13, 2016 | 11:59 AM
BrianCunningham
at least on LT1/4
To new heads = blow by, HELP!
