My brain is over loaded on research, so I need just a very simple way to find TDC on number 1 cylinder with intake off, so distributer is also out. I finally feel confident about how to set pre load, but I just need to be sure I'm at TDC before I start or every adjustment will be wrong. It took me for ever to understand how to adjust preload, but with lots of help from members on this forum, I now think I have it down
I did that while having wife hold her finger over the hole, but she kept telling me she felt air each time crank came around to TDC. Now that I am thinking about it, I didn't have any of the valve train gear on. That would mean both valves would always be shut and air would come out of plug hole no matter what. I am such a dumb s%%t
Make a paper ball put it over #1 spark hole bump starter ,do not crank it, when air blows paper ball using a wrench rotate balancer until timing mark aligns with 0 on timing tab. Or with timing mark on 0 if both valves are closed and you can spin push rods with fingers it's tdc#1 if not its tdc #6. So rotate crank one turn and it will be tdc#1.
Make a paper ball put it over #1 spark hole bump starter ,do not crank it, when air blows paper ball using a wrench rotate balancer until timing mark aligns with 0 on timing tab. Or with timing mark on 0 if both valves are down and you can spin push rods with fingers it's tdc#1 if not its tdc #6. So rotate crank one turn and it will be tdc#1.
The op states he has no valvetrain gear on the car. All valves are always closed. The cylinder will blow air out of the plug hole during both compression and exhaust strokes. To the op, loosely put the valvetrain gear on and look at the rockers as the motor is turned. When rockers are both down on tdc#1, you are where you want to be.
I would think with Intake off you could look rite into the cam lobes or drop in the 2 lifters and see valves are in the compression Directly.
Here is a link on how to just take what he said about the rockers and translate to lifter position
