which opti
Old Jun 18, 2016 | 04:30 PM
mrodoc's Avatar
mrodoc
Default which opti
Yes, yet another opti question. I just finished my build. My opti ran perfect before I took my stock 1994 opti with 49k miles apart. It needed a new rotor, literally fell apart, and a new cap, the contacts had some corrosion. The disc had some light rust centrally only, near the rubber seal which was hardened, but was otherwise ok. I also purchased an AIP from Sac City. Which should I use? Gary
Old Jun 18, 2016 | 05:35 PM
antfarmer2's Avatar
antfarmer2
Get a new cap and rotor make sure you use locktight if you use the new one save the old one.
Old Jun 19, 2016 | 05:37 PM
qwiketz's Avatar
qwiketz
I'm kind of in the same boat. I have a 55k stock one with the same corrosion on it. I also have a dynaspark which I'm going to use since it's vented. I could do cap and rotor but since I have a dynaspark... well, why not.
Old Jun 19, 2016 | 05:53 PM
856SPEED's Avatar
856SPEED
Where is dizwiz?????
Old Jun 19, 2016 | 07:47 PM
qwiketz's Avatar
qwiketz
Seriously... "If it's got a Mitsubishi sensor".... Well you guys know the rest!
To which opti
