Recently My Inflatable Restraint Lite came on and flow charts and tests brought me to the fact that my clocking spring / coil has a open and tests have proved it, So does anybody know what other Vehicles Share the clocking spring G.M. 26011473 I so far believe 87 thru 93 Cad. Allantes and 92 thru 99 Buick Road masters are there more vehicles that share?
I would like to pull from a locale source if possible so I can test it before pulling the part.
What year car do you really have? You got that # from where?
'91 - '93 Corvette, '91 - '93 Berreta, '91 - '93 B-bodied GM, '90 - '92 Camaro, Firebird - there are others but you actually need to confirm the connector at the column base and the connector at the SIR.
You can't rely on the # on the label you've mentioned.
***Take the most current part # 26013854 and a "local" GM dealer should be able to provide you with a more complete list BUT some of the applications they may give you would have required other changes along with the coil. An example would be a '90 Corvette but it's use requires a '91 SIR, DERM etc.
Thanks with those car's added to the possible donor list the mission should be a success
