Trans problem still present...
Old Sep 9, 2002 | 05:20 PM
Bravery's Avatar
Bravery
Default Trans problem still present...
Had the transmission fluid and filter changed two weeks ago. Trans temperature has dropped to a reasonable 185-200 degrees on normal driving (no traffic). At various times, under WOT, the trans will still hit the rev limiter on shifts. It is not a continuous problem as it will act up on one run then I do it again and it shifts fine. Traction control is turned off.
Thoughts?
Old Sep 9, 2002 | 05:49 PM
vader86's Avatar
vader86
Default Re: Trans problem still present... (Bravery)
it sounds like you need to adjust the TV cable again
