PIR first run new setup
Old Jun 25, 2016 | 12:24 PM
ormarker85's Avatar
ormarker85
Default PIR first run new setup
First pass. 12.9. Fastest pass 12.66 @108. This all down from 13.2
Mods AFR 195 and long tube headers. Running drag radials. 1.85 seconds 60'
Should've gone bigger on the cam. Also had a full tank of gas and spare tire in but helps keep some weight over back tires. Next trip will go with limited gas, no tire and cut back the plugs. Hopefully can get into #wongsperformanceengineering and fine tune
Very happy with results
The video is not the fast pass. Needed to drop tire pressure. Was spinning off the line like crazy
