New battery questions! Help please!
Old Sep 9, 2002 | 07:54 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
Default New battery questions! Help please!
My battery is finally RIP.. :(
So, tommorrow morning i need to go buy a new one.
Any suggestions? I need to go cheep, under $50. I'm thinking Exide, since i've had good experiances with them before.
:yesnod:
Also, what tools do i need to remove the battery cables?
Old Sep 9, 2002 | 08:05 PM
c4cruiser's Avatar
c4cruiser
Default Re: New battery questions! Help please! (Mervz)
5/16 should be the tool to remove the cable bolt. If you have set a limit on price, look for a battery that has the longest warranty. Also, try to get the largest number for CCA's that fits the budget. You should get a minimum of 650 cold cranking amps/hr.
Old Sep 9, 2002 | 08:15 PM
dbwade36's Avatar
dbwade36
I put an Excide in my Vette. 84 month one. Cost around $50. It has worked just fine so far. Be careful to properly realign your panel after installation, or your door may scrape it.
Old Sep 9, 2002 | 08:40 PM
JonM's Avatar
JonM
Check this out .... http://corvettemagazine.com/2001/oct...ttery/bat1.asp
Old Sep 9, 2002 | 09:15 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Default Re: New battery questions! Help please! (JonM)
Very cool, thanks alot for the link!! :cheers:
Old Sep 9, 2002 | 09:37 PM
Ender85's Avatar
Ender85
Default Re: New battery questions! Help please! (dbwade36)
I'd go with a Wal-Mart battery which is pretty cheap and has 3 yr. replacement warranty and 7-yr partial warranty. These are the best deal's you'll get anywhere.
Old Sep 9, 2002 | 10:12 PM
WhiteIce-ChicagoRoss's Avatar
Default Re: New battery questions! Help please! (marthpodi)
One Word SAMS CLUB got mine there for under $50 750 CCAs. Its a Champion very nice battery. :yesnod:
To New battery questions! Help please!
