1984 UK Pro Street C4
Car was built in 1999 but after completion sat in a speed shop on display till 2014.
The Previous owner bought the car and did a few bits to get it in running order and covered about 1000 miles in it till i bought it 4 days ago.
Has a few small issues namely a small oil leak from the timing cover that will be sorted in two weeks when i move to my new property and get it into my garage.
I have a massive build folder and below is the engine spec/build
4 bolt main L82
Eagle 383 Cast Crank
Hypereutectic Pistons
Claimer +30 rings
Arp headbolts
Brodeix Track 1 Heads
Crower Roller Lifters
Crane Chromoly PushRods
Crane Energizer Roller Rocker Arms
Peter Jackson Timing gears
Hooker Super Competition Headers
Edelbrock 2925 Super Victor Intake manifold
Holly 4150 750 Carb
MSD Pro Billet distributor
Taylor 409 Plug Wires
150hp Nitros (currently disconnected)
Street Scoop
Mcleod 11 inch strip pressure plate
Mcleod Kevlar clutch
Mcleod Steel flywheel
Arp flywheel bolts
Crower 00425 Street Roller Performance Level 4 Camshafts
Comp Cam 12-000-8 Street Roller Cam
Im not sure what cam is in it as i have a receipt for both lol.
The car has never set a 1/4 mile time since it was built but after i get a set MT et rears and sort the oil leak etc i will run it before i look for some more power
I don't know what to say other than thanks for sharing.
Neat looking ride, needs a forged bottom end and a 6-71 blower
The crower cam is the 00425
lol the spare wheel is from my 87 model which i sold.
Even with the cast bottom end and hyper pistons i have done a bit of research and seen that there shouldn't be a problem running a low boost blower or small nitros shot.
Thoughts?
Looks mean and thanks for sharing pics of it.
I have used Keith a few times, really nice and helpful person
Most of the front end is stripped apart from the harmonic dampener (need to grab my pullers) as i believe the leak is from the front seal/ timing case cover.
Seeing as i need to drop the sump to change the gasket properly i noticed my sump is in poor condition and seems to have been welded after hitting something back in the day,
So seeing as its coming off anyway i was going to order a replacement. Is a standard 350ci sump going to be ok with the 383 stroker kit thats fitted?
I may order a shallower sump as well to prevent damage later in life and recommendations
One hurdle i have got is the crank bolt (arp) snapped when undoing.
I need to drill it out and retap it and fit a standard crank bolt as this is the 3rd time an arp bolt has broken on me.
Could someone tell me the thread size and pitch so i can order the correct tap.
cheers
