93 Air Conditioning Problems
Old Jun 28, 2016 | 04:57 PM
Meskelld's Avatar
Meskelld
1st Gear
Default 93 Air Conditioning Problems
I have a 93 corvette that is giving me air conditioning problems. My AC blows out of the defroster and floor vents, but not the front-facing vents. No matter which buttons I press, air will NOT blow out of the front vent at all. Ive tried changing the T shaped "valve" under the plastic cover on the passenger side of the engine but that didn't do anything. I had the AC control panel cleaned out which didn't do anything. What could the problem be? I've been told by a friend that the blend door could be the problem but I read that when this is the problem there's usually a clicking sound associated with it, which I do not have. If anyone could give me insight on how to fix this I would appreciate it!
Old Jun 28, 2016 | 05:25 PM
Kevova's Avatar
Kevova
Most of the time its a vacuum leak under the hood. Car uses vacuum motors or diaphragms to move air distribution doors do you hear vacuum leaking under dash? The blend door is controlled by programmer on C68 (auto a/c) or a cable on C60 (manual a/c). Blend door controls air temperature "blends" hot and cold air. Do you have a FSM? The vacuum harness for a/c programmer is under right side of dash. You should see it if you remove right lower dash. Removing dash glove may also help in seeing whats going on. There should be noticeable vacuum at connector for programmer. Connector maybe retained by 7mm nut.
