Autometer Gauge conversion
Old Sep 9, 2002 | 10:37 PM
kawboy5792's Avatar
kawboy5792
Default Autometer Gauge conversion
would it be possible to convert the LT1 dash to all autometer gauges? :confused:
Old Sep 9, 2002 | 10:49 PM
bogus's Avatar
bogus
Default Re: Autometer Gauge conversion (kawboy5792)
I have been thinking about this myself.
I donno if you would convert via the factory sensors, but I am sure it can be done with the autometer sensors and such... the wiring would be a bit scary...
but the end result would be way cool!
Old Sep 10, 2002 | 08:57 AM
STREETKNIGHT's Avatar
STREETKNIGHT
St. Jude Donor '03-'04-'05-'06-'07
Possible...? Yes
Old Sep 10, 2002 | 11:08 AM
johndezman's Avatar
johndezman
Default Re: Autometer Gauge conversion (STREETKNIGHT)
i think i remember someone documenting this on this forum....
Old Sep 10, 2002 | 01:18 PM
-=Jeff=-'s Avatar
-=Jeff=-
Yes you can. All the Analog Gauges on the dash are directly wired to the sensors.. You should be able to get the Autometer gauges that work on the stock sensors.. or use the Autometer sensors and stock Wiring.
I think the fuel gauge and Speedo will need to be wired from the CCM. I am not sure on the fuel gauge though. it has been a while since i looked at the cluster wiring.
The tough part will be getting everything to fit in the Cluster space
Here is an example for the 89-older C4 http://www.batee.com/corvette/dcrg/replace.shtml
Old Sep 10, 2002 | 02:25 PM
danno85's Avatar
danno85
Here's what I'm doing in my '85:
[img]http:\\home.austin.rr.com\dancurrie\c4ga ugecluster.jpg[/img]
Definitely lots of work (I'm rebuilding nearly the whole car though).
I like the way it's turning out so far.
Dan
[Modified by danno85, 12:26 PM 9/10/2002]
To Autometer Gauge conversion
