Hello, I have a 1990 non ZR1 , last weekend I'd replaced the battery. I started it ran fine for about 30 seconds, then it ran real rough and stalled. I got it to start again the only way I got it to start is press down on the gas pedal, and when it did start it had practically no throttle response, ran rough for about 10 seconds than it stalled again. Not the only way I get it to fire off is spray stating fluid down the TB. I went check the fuel press I had no fuel press at all in the rail. So to eliminate the fuel pump I Jumpered 12 volts to the fuel pump,I got pressure at the rail. I go to start nothing. So im assumming the injectors are not firing. I had tried jumping out the oil pressure switch behind the distributor , got nothing,so I went to check the voltages from the tps, I not only have no voltage coming from it (signal to ECM) I have no voltage (5VDC) going to it. Im going to try retrieve any codes this weekend, BUT im thinking the ECM had died on me. Is there any quick test I can do, to check if this the case before I shell out money for a remag one??
What do you mean "I got pressure at the rail"? How much pressure? How long did it hold? Did you pull out the hose to the fuel pressure regulator and see if there is gas in it? I would let the car sit for a couple of minutes and turn it on to run but don't crank. See if the pressure jumps up. If it does, see how long it stays up. If not, you have a pump issue be it electrical or mechanical.
Before you rule that out, take a noid light and hook it to an injector from each bank. See if they light up. You can probably rent one from an Autozone. I did.
Check fuses no voltage possibly fuseable link. Does check engine light work? Do you have FSM or at least a good wiring diagrams. If ecm failed it will have 12v to it and no 5v coming out for sensors.
Thanks for the reply, when you first turn the key, the fuel pump should run about 2 seconds or so the pressurize the system. My pump is no doing that, the only way it comes on is when I run 12volts directly to the pump bypassing the relays and fuses, pressure switches. I dont why knowing the pressure would have anything to do with that symptom? What I mean by rail is the the 2 rails running down by the plennum the injectors connect to.
What aklim is getting at is what is your fuel pressure, specifically, in PSI? I don't think that you know., b/c I don't think that you checked it w/a proper gauge. Getting fuel spitting out of the schrader port isn't a pressure test.
Your symptoms, "ran fine for about 30 seconds, then it ran real rough and stalled. I got it to start again the only way I got it to start is press down on the gas pedal, and when it did start it had practically no throttle response, ran rough for about 10 seconds than it stalled again"
...are very aligned with low fuel pressure. SO...is there a quick test that you can do? YES! Check the fuel pressure w/a proper gauge.
Yes but just because it comes on for 2 seconds doesn't mean you are getting the right amount of pressure. If it pressurizes to 2 psi, you are hearing the pump but you don't have enough pressure to do squat. If your regulator leaks all the pressure off, same thing. We need you to put a real fuel pressure gauge on the schrader valve to see what is going on.
We'll be happy to guess and throw parts at it all day long till we get lucky but your wallet might not like it.
The OP stated he jumped power to get fuel pump to come on and didn't have 5v going to TPS. There is ECM issue that needs to be resolved first. After ECM is able function correctly then other remaining issues can be dealt with.
You don't know that. That is a guess. It's more likely that the OP has a bad fuel pump relay, or a wiring harness issue. Either of those could cause his "pump no run @ key on", symptom. Diagnose.
The FIRST thing he should do though, is put a proper gauge on there so he can actually see, WTF is going on with his pressure, rather than guess.
I didn't say ecm failed, but it wasn't working. I believe there is a wiring concern related to battery voltage getting where it needs to be. 12 volts not getting to ECM is still an ECM issue because it not working. If jumping fuel pump would get car to start. Then you would believe ecm and related circuits were ok and focus would be on fuel pump circuit and related components. Maybe OP will post what has been found so far.
IIRC, it primes for 2 seconds and will NOT prime again for a minute or so. IOW, for a set amount of time after priming, if you turn it off and back on, it won't prime again. That is why I suggested getting a gauge on it and turn it on to see if it does the "initial prime".
Update, I placed my scope on every injector, and I receive no pulses at all. I have no engine light at all when I first turn the key, and I have voltage to the pink and black wire that powers the ecm, and I do have a FSM, Im going to confirm I have a good ground to the ecm, but im really starting to think it is the ecm. Any thoughts??
I don't know why my signature doesn't turn up but if it did you can see my mods. Other than that, my location is set in the profile. Maybe you should do the same so that if someone is nearby they can lend a hand or better yet, lend you a PCM so you can test the thing before you buy? Problem is if you take it past the door, win, lose or draw, you own the thing.
There are 2 orange wires that should have battery voltage all the time. Terminals D17 and C1 they are powered by a fusible link. Fusible link should be near battery. I would look at that before replacing ecm.
Pulling the codes would be a start ; CCM (Comms ) problems can cause no injector signal
It sounds like the fusible link that powers the ECM is blown (or the ECM power connector is disconnected).
This picture shows the fusible link (between the connector and the round black insulator covering the splice between the fusible link and the regular wire (at the bottom of the connector)):
Usually this connector is buried under the brake booster so it can be hard to find.
Hello, after being out of town for a week, and after receiving my FSM in the mail, I did some more investigating, and the fusiblelink that you're refering to is blown, will go to Napa tomw and get a new one, the wire looks like a 18 gauge or so, im thinking a 10 amp?
