Glass top interchangeability
Old Sep 10, 2002 | 08:49 AM
Bgreenard's Avatar
Bgreenard
Go Fast
Default Glass top interchangeability
I have a 93 coupe and I am looking for a used replacement top. What years will fit and what years wont. I'm getting conflicting information.
Thanks in advance.
BG :confused:
Old Sep 10, 2002 | 08:53 AM
Slick94's Avatar
Slick94
Default Re: Glass top interchangeability (Bgreenard)
What is the problem with yours? Is it destroyed? If it's acrylic, you can get the piece replaced at Astro Tops in Alabama for $450.
Old Sep 10, 2002 | 09:32 AM
Bgreenard's Avatar
Bgreenard
Go Fast
Default Re: Glass top interchangeability (Slick94)
I have a line on a top from a guy that has a 95. He states that he bought this top from a late 80's ( I think 87) and it doesnt fit his car. Something about the brackets. He said it should fit my 93. See my problem. Is he correct?
BG
Old Sep 10, 2002 | 09:58 AM
The Rex's Avatar
The Rex
I was told that tops match up to body styles. 84-90 are the same & 91-96 are compatable. I could be wrong, but I would like to know for sure as well. I'm looking for a glass top for my 96.
Old Sep 10, 2002 | 11:42 AM
85vetteguy's Avatar
85vetteguy
3 different tops as follows;
84 - early 86
late 86 - 88
89 - 96
If that top does not fit his 95 it will not fit your 93 . If you buy an 89 or up , you should be safe, Guy
[Modified by 85vetteguy, 9:44 AM 9/10/2002]
Old Sep 10, 2002 | 01:41 PM
Bgreenard's Avatar
Bgreenard
Go Fast
Default Re: Glass top interchangeability (85vetteguy)
Thanks Vetteguy. If anyone is interested the top I was taking about is on EBay. http://cgi.ebay.com/ebaymotors/ws/eB...tem=1858280753
I think I'll pass on it.
BG
[Modified by Bgreenard, 2:05 PM 9/10/2002]
Old Sep 10, 2002 | 01:44 PM
Bgreenard's Avatar
Bgreenard
Go Fast
Slick94 tell me more about Astro Tops. Have you ever used them? I have heard questionable things about the aftermarket tops.
BG
Old Sep 10, 2002 | 02:36 PM
insanegt1's Avatar
insanegt1
If the top is acrylic it can be buffed up to look like new. I started with #800 wet sand paper. Went to #1200 then used polishing compound with a buffer. Looks like new. :cheers:
Old Sep 10, 2002 | 02:44 PM
Bgreenard's Avatar
Bgreenard
Go Fast
Default Re: Glass top interchangeability (insanegt1)
Unfortunately my top was damaged by a cigarette the some #%_! left on my top and left a deep scar. I'll have to replace it.
[Modified by Bgreenard, 1:57 PM 9/10/2002]
Old Sep 10, 2002 | 02:56 PM
Bgreenard's Avatar
Bgreenard
Go Fast
I just bought a repacement top from Davies Corvette 800-236-2383 (John) with the the original hardcoated acrylic. Its 799 outright or 599 if you send them a good replacement frame. I'll let you guys know how it turned out.
BG
Old Sep 10, 2002 | 08:08 PM
Slick94's Avatar
Slick94
Sounds like you got it taken care of. I had my acrylic replaced by Astro Tops a couple of years ago. They did a great job and it looks like new today. Can't tell it's been replaced. Mine was the bronze coated acrylic.
Old Sep 10, 2002 | 09:05 PM
Wheelman's Avatar
Wheelman
does the astro top replacemet tend to craze like the oem one does??? I like having a glass top, but mine has all kinds of stress fractures in the acrylic. I dont want to buy another one if its just going to happen again......
Old Sep 10, 2002 | 09:19 PM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
I have heard nothing but bad news from AstroTops. I believe it was Mr. Mojo who said the GM top is a much higher quality product.
By the way tops from 89-96 will fit your car.
[Modified by Drewdog, 8:45 PM 9/10/2002]
Old Sep 11, 2002 | 06:38 AM
jshope's Avatar
jshope
[QUOTE]3 different tops as follows;
84 - early 86
late 86 - 88
QUOTE]
I can definitely verify this part. As a matter of fact, when I had early-86 replaced at the dealer, they kept ordering a new top for mine, but would not fit. As it turns out, GM (apparently) does not make the one for 84-86E anymore and they had to order a new kit which replaced the brackets in the windshield header so the top that was ordered would fit.
FYI - this wouldn't help with a cigarette burn on your top, but for future reference, I had a crack in my top and the insurance company got the glass, the conversion kit, and the front (foam) molding replaced for me. :)
Old Sep 11, 2002 | 08:01 AM
Slick94's Avatar
Slick94
Default Re: Glass top interchangeability (Drewdog)
"I have heard nothing but bad news from AstroTops. I believe it was Mr. Mojo who said the GM top is a much higher quality product."
I can't speak for others but after two years mine still looks like new. They were prompt and it looks like factory acrylic. I did send in my top and got back the same frame because I marked it, perhaps this makes a difference.
[Modified by Slick94, 7:05 AM 9/11/2002]
Old Sep 11, 2002 | 12:21 PM
insanegt1's Avatar
insanegt1
Default Re: Glass top interchangeability (jshope)
Do you know where the dealer got just the foam for the front?? Or do you have to buy the whole foam kit??
To Glass top interchangeability
