Camshaft postion sensor
Old Jul 7, 2016 | 10:43 AM
robertlee390's Avatar
robertlee390
Cruising
Default Camshaft postion sensor
I am doing a tune up and replacing the rotor and cap. Is the camshaft position sensor worth replacing. and if so, where do i find one. Looked all over.
Old Jul 7, 2016 | 10:47 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Probably not.
It would help us, to help you, if you posted the year of the car.
Old Jul 7, 2016 | 11:18 AM
THE 383 admiral's Avatar
THE 383 admiral
this question is for 97 and above. "Only"
the 96 LT1/LT4 has a crank position.
Old Jul 7, 2016 | 11:49 AM
robertlee390
Cruising
Originally Posted by Tom400CFI
Probably not.
1994 standard.
Old Jul 7, 2016 | 12:43 PM
mtwoolford's Avatar
mtwoolford
1994 standard.
on a 22 year old car there isn't hardly anything that's not worth replacing...but a non existent crank position sensor on your 94 would not be one of them.
Old Jul 7, 2016 | 12:48 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
He asked about a CAM position sensor, not crank...and the '94 LT2 most certainly does have a cam position sensor; the primary side of the opti. Should that sensor be replaced? Not in my opinion. If it's working, I'd leave it alone.
Old Jul 7, 2016 | 02:31 PM
robertlee390
Cruising
Thanks !
To Camshaft postion sensor
