Hard to shift when cold
Old Sep 10, 2002 | 03:32 PM
all4c4lt4's Avatar
all4c4lt4
Default Hard to shift when cold
After start up, it is hard to put the car into a gear, especially reverse (maybe because I use that one first :) ) after about 2 minutes of driving and everything is warm, shifting is no problem. I have read other posts talking about clutch fluid, but I don't know how or where to check this. What could be the problem and resolution? Thanks in advance!
Old Sep 10, 2002 | 03:34 PM
scorp508's Avatar
scorp508
I would change the gear oil in the tranny.
Old Sep 10, 2002 | 03:45 PM
T1Kilr's Avatar
T1Kilr
Default Re: Hard to shift when cold (all4c4lt4)
Another thing... check the level of the clutch fluid and possibly bleed the system. :cheers:
Old Sep 10, 2002 | 03:48 PM
T1Kilr's Avatar
T1Kilr
forgot to mention.... the clutch mastercylinder is under the computer ecm on the driverside of the firewall. Remove the 2 10mm(i think) nuts and lift the ecm off its bracket and lay it on the windshield and voila... access to the clutch master cylinder!
Old Sep 10, 2002 | 11:14 PM
Mark93's Avatar
Mark93
I was having trouble getting into first or reverse, but not necessarily just when cold. The clutch fluid was low and when I topped it off it shifted ok. Turned out that the clutch slave was leaking.
To Hard to shift when cold
