Need help on connection
Old Jul 9, 2016 | 05:16 PM
mlm0's Avatar
mlm0
Default Need help on connection
1989 stock with auto trans
In the process of putting my engine back together, and I can't remember what hose connects to the metal tube on the rear of the manifold, just before the distributor, location shown in picture. I took lots of pictures, but none of mine help. Looked in FSM and good not find it
Thanks in advance
Old Jul 9, 2016 | 05:41 PM
mlm0's Avatar
mlm0
Never mind, I found it. It connects into hose that connects to cooling system. Don't really know what it does
Old Jul 9, 2016 | 10:07 PM
HAD2HAV2's Avatar
HAD2HAV2
You got it, very little. I see you reused your T-40 torx head bolts. I had one torx bolt round out and had the cut/chisel it off.
Old Jul 9, 2016 | 10:19 PM
mlm0's Avatar
mlm0
I had same problem. I had to replace two of them with hex head bolts. I got lucky, one I was able to back out with torx tool, but on the other I was able to hammer in an Allen wrench tool and back it out
Old Jul 9, 2016 | 10:46 PM
HAD2HAV2's Avatar
HAD2HAV2
I removed the torx stud after I pulled the head off. Took anti-rust spray, 24 hours, and Vise grips to pull it out of the head. Went back with ARP's with a 3/8 inch cap. Never again. Did you have any porting done?
Old Jul 10, 2016 | 07:01 AM
mlm0's Avatar
mlm0
No porting. Just valve job and had heads milled flat
To Need help on connection
