Suggestions....Power Effects too quiet
Old Sep 10, 2002 | 05:59 PM
LT4toy's Avatar
LT4toy
Navigator
Default Suggestions....Power Effects too quiet
Help me.....
Should I remove the resonator and go with straight pipes? Or is there another suggestion. (Must leave the cats on.)
I NEED LOUD
Old Sep 10, 2002 | 06:04 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Re: Suggestions....Power Effects too quiet (LT4toy)
take the power effects off & install hooker aero chambers! i set off car alarms with mine! :yesnod: :D
Old Sep 10, 2002 | 06:35 PM
Red Rocket's Avatar
Red Rocket
Go with long tubes, high flow cats and no resonator with the Power Effects pipes and modules in back.
Old Sep 10, 2002 | 06:38 PM
Blk-94's Avatar
Blk-94
Install Flowmasters.. :D
Old Sep 10, 2002 | 07:00 PM
vader86's Avatar
vader86
Remove the resonator or go with straight pipes
Old Sep 10, 2002 | 09:29 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Suggestions....Power Effects too quiet (vader86)
Try the resonater removal. B&B Triflow is the next step in noise.
Old Sep 10, 2002 | 10:50 PM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default Re: Suggestions....Power Effects too quiet (Red Rocket)
I think this setup will get you what your after. :yesnod:
[Modified by 365ZUM, 9:50 PM 9/10/2002]
Old Sep 10, 2002 | 10:54 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Re: Suggestions....Power Effects too quiet (365ZUM)
My Polished Dynomax Turbos are too loud! We need to switch!
Try removing only the pre-cats if you have to pass emissions.
Old Sep 10, 2002 | 11:09 PM
Scout's Avatar
Scout
5th Gear
I ran my power effects wide open when I first installed them. I love the sound but it wasn't as strong as I had hoped. Got rid of precats and added a high flow cat and it is just right now. I did find after a couple of weeks they did become noticibly noisier just driving. If I am traveling interstate for any distance I crank it down to the third position to kill the resonance. In wide open position it is for all practical purposes straight though. So to get more volume you have to open it up up stream. good luck.
Old Sep 10, 2002 | 11:18 PM
Bgreenard's Avatar
Bgreenard
Go Fast
Default Re: Suggestions....Power Effects too quiet (Scout)
Dude you are hard core. My PE is border line too loud for me, especially on long trips. Take the resonators off and I'm sure you will eventually go deaf! Good luck
BG
Old Sep 10, 2002 | 11:35 PM
republicanhunk's Avatar
republicanhunk
my buddy has pe and i find it pretty loud when hes in the throttle. try a lower gear- rpm=db :cool:
To Suggestions....Power Effects too quiet
