1987 R-12 System
I am finally working on my ac system and was wondering what the best way to save the existing system and recharge it would be. Is Envirosafe r12 legal, and effective? I have yet to do diagnostics so if I find a bad compressor and I likely will, should I convert when I replace that instead to R134a? Ive looked at other forums and found Envirosafe R12 may be illegal for a previously R12 system, but I am unsure if it currently is unacceptable to use as these forums were old. Any help would be great!
thanks
No need to change ANYTHING over--it's safe to use with either mineral (12) or ester (134a) based oils. You don't even need to pull the system to full vacuum before installing...it installs at atmospheric pressure and will not cause internal corrosion when mixed with moisture like R12 and 134a will...hence not having to evacuate the system.
I got 34º air at the center vent on a 90º+ day. Awesome stuff and 100% legal. It's the only replacement refrigerant I use now.
12 cans Enviro-Safe Industrial R134 134 134a Replacement Refrigerant
Use it once and you'll be sold for life. The only reason I use my Robinair vacuum pump anymore is simply to make sure the system I'm working on is leak free. Once verified, open the system to atmospheric pressure and charge. You can do the math and put in the converted R12 to Envirosafe amount, but I prefer to use my gauges and charge by the pressures. If necessary or desired, you can tweek your low pressure switch for your desired cycling pressure.
Remember, get the "INDUSTRIAL" refrigerant. Also, feel free to call their tech support if you have any questions. They are friendly, extremely knowledgeable, and will take all the time you like to discuss their product in as much detail as you need.
Over 40K with this refrigerant in my 87 with no issues....I also run this in my 1994 Jimmy and 1990 LeSabre.
Hey guys really appreciate the replies, I am assuming all my old R12 Leaked out long before I bought the car, not sure tho. before I Recharge the system do you recommend buying a gasket kit and replacing the gaskets for the a/c system? and how difficult would that be. Or should I just just giving it a try and seeing how long it lasts. Thanks!!
Actually the can's label clearly states R134! Seems a little fuzzy and mixing R134 and R12 is not something I would do. The safe bet would be to wrestle up some R12. There's plenty of it on line. (No offense meant, just my $.02!)
