1995 vette Front wheel hub replacing
I don't know if already there's a thread about this, but today i've replaced front hubs so i thought to share with you my work
Work is pretty symple need j
ust 21mm socket for caliper bolts,
15mm socket and 15mm box end wrench for hub bolts,
Torque whrench
Ratchet whrench
Some degreaser, (white spirit, nitro thin er or acetone)
The most of time i've lost was been to knuckle and alu parts very very dirt.
So ok this is what you will find, once you get out tire and put car on floor jack and jack stand, remove two caliper 21mm bolts and rotor...
Before unscrew bolts, remove abs sensor bracket is required, 15mm here too. Disconnect abs connector and put it out of the way
15mm Box-end whrench inner side of the hub, and 15 socket throught hub hole, is the right way i think
This pic is already new hub on.... Anyway is possible to put racket with socket even in different ways...
On Tie rods greaser point, some grease was came out (i don't know if it is normal or not) and becam solid... I had to remove it with with screw driver
Anyway some hour later this and a lot of work later knuckle is very shining
