Under instrument panel relays
Old Jul 29, 2016 | 07:47 PM
mquinnette's Avatar
mquinnette
Cruising
Default Under instrument panel relays
I just found that of the 4 relay connectors only 3 have relays installed.
I believe it is the fuel pump 2 relay as shown in FSM. Can this be as left the factory?
1990 base coupe
Old Jul 29, 2016 | 09:16 PM
WVZR-1's Avatar
WVZR-1
1990 base coupe
Yes no problem - in '90 the IP harness is the same for the "base" as the ZR-1/LT5 - that spot would have been "filled" had it been a ZR-1.
Old Jul 30, 2016 | 06:38 AM
mquinnette's Avatar
mquinnette
Cruising
To Under instrument panel relays
