squeaky
Old Jul 30, 2016 | 09:02 AM
valiant68's Avatar
valiant68
Default squeaky
hi guys, I have a 92 when taking off from a slow start it makes a squeak squeak squeak sound coming from the left side the faster I go the sound goes away, anyone ever experienced this issue?
Old Jul 31, 2016 | 10:47 PM
Izzy Dizzy's Avatar
Izzy Dizzy
Default squeaky
How many miles on the car? Is the noise coming from the rear or front? Rear squeaky noise could be the start of a bad u-joint or a brake disc pad.
Old Aug 1, 2016 | 12:37 AM
Cliff Harris's Avatar
Cliff Harris
Classic symptom of a bad U-joint.
If the roller bearings get rusty the cap can't turn and the cap turns in the clamp, which makes the squeaking noise.
Old Aug 1, 2016 | 04:28 AM
valiant68's Avatar
valiant68
It has 136,000 miles with all original parts
valiant68's Avatar
valiant68
Left rear
Old Aug 1, 2016 | 04:40 AM
Joe C's Avatar
Joe C
first, pull the wheel and check the brake pads - sounds like a wear indicator. if its a pulsating squeak sound, it could be caused by a slightly warped rotor. does it go away if you lightly apply the brakes? the reason it may seem to go away, the faster you go, could be, you're just not hearing it for the road noise.
if brakes are good, try to isolate the noise - could be u-joints or bearing/hub assembly, but my best guess, most likely, it's the brake pads.
Old Aug 1, 2016 | 09:04 PM
valiant68's Avatar
valiant68
Thanks Joe, I will check the rear pads, I have a low pedal also may be the problem.
Old Aug 1, 2016 | 09:15 PM
Izzy Dizzy's Avatar
Izzy Dizzy
Excellent post!
Old Aug 1, 2016 | 09:22 PM
valiant68's Avatar
valiant68
Old Aug 1, 2016 | 10:12 PM
Izzy Dizzy's Avatar
Izzy Dizzy
Beautiful color!
Old Aug 7, 2016 | 12:38 PM
valiant68's Avatar
valiant68
I found the problem guys, it was the inner u joint, took it apart and it had the red rust all around the cap replaced all 4 both sides good as new, thanks
Old Aug 7, 2016 | 12:48 PM
Izzy Dizzy's Avatar
Izzy Dizzy
Do your new u-joints have fittings so you can grease them?
Old Aug 7, 2016 | 12:51 PM
valiant68's Avatar
valiant68
yes they recommended greasing them after installiation so I did.
Old Aug 7, 2016 | 12:53 PM
Izzy Dizzy's Avatar
Izzy Dizzy
Cool. You can grease the occassionally. Sometimes it's a little tricky to get the tip of the grease gun in there, but if you rotate the axles you'll be able to get it done. Best news is you'll never have to replace them again!
Old Aug 7, 2016 | 12:57 PM
valiant68's Avatar
valiant68
I will have to say that was a pretty big job lol, after I got the control arm loose wasn't to bad after that.
To squeaky
