84 Automatic Shift Knob
Old Jul 30, 2016 | 04:19 PM
OldPoop55's Avatar
OldPoop55
Default 84 Automatic Shift ****
How do I get that thing off? My boot is falling apart and I would like to replace it. I looked in the shop manual but unless I missed it, I didn't see a disassembly page. Can't figure out how to do it..
Help please.
Old Jul 30, 2016 | 04:27 PM
s carter's Avatar
s carter
Help please.
With a small to medium screwdriver pry up the push button it should slide off the push shaft with a little retainer (sometimes left behind on shaft or in button) use a small set of snap ring pliers remove the ring. Now granted I will say that the **** can be a little stuck from time but usually from spilled coffee or soda, but I have found that they usually come off with a little twist back and fourth and small hit of WD-40 at the same time PULLING UP IT DOESN'T UNSCREW IT SLIDES OFF
