L98 distributor removal *sigh*
How does one remove the distributor? Taking the cap and rotor off is simple, but what about the rest of it? Do I have to take other things apart to remove the distributor? The only time I've seen it removed was when an L98 gets an overhaul and the intake, valve covers, and several other components are removed.
Please help.
https://www.youtube.com/results?sear...ibutor+removal
Take pictures of where the wires connect before you remove it
https://www.bing.com/images/search?q...3o0&ajaxhist=0
You can see it just under the Arrow (internet stock photo)
Gary
for installation, set the distributor in place - position the rotor to that 30°, mental note position and slowly drop the distributor. as the gears engage, the rotor will rotate CW, and with a little "wiggle-giggle" fully engage with the oil pump shaft. the rotor should locate itself exactly to the original, mental note position. the four (4) distributor cap mounting screws should be somewhat squarely positioned (perpendicular and parallel), to the CL of the engine. distributor clamp and bolt, reconnect the electrics, plug wires in proper firing order, and set the timing, and you're off to the races -
