1987 engine installation advise
1. Should/can I attach the engine mounts to the block at engine stand and drop the engine with the mounts, and simply stick in the two thru bolts? Or not enough clearance and need to put engine mounts first and the three small bolts after dropping the engine in?
2. Can I fix the pulley at stand, and still have enough clearance to get the engine in? Or need to drop the engine first and then attach the pulley when engine in place?
3. What is the best/right way to install the AIR pipe that goes to catalytic converter? When I removed the engine I actually took the heads off when engine still at car and managed to drop the whole front exhaust without separating the AIR pipe, still all as one piece. Wondering if should cut off the crimp ring from back (cat) or front (check valve), and whether the pipe should be put in place before dropping the engine, or can still stick in either from below (without the check valve) or from top (separated from cat) after engine in place?
thanks
Good luck man, keep us posted.
