Re: LT1 G104 Ground Socket Size?
Old Aug 1, 2016 | 11:43 PM
Dougs63's Avatar
Dougs63
2018 C4 of Year Finalist
2016 C4 of Year Finalist
2015 C4 of Year Finalist
Default Re: LT1 G104 Ground Socket Size?
Anyone happen to know the socket size required to fit the already next to impossible to reach G104 Ground Bolt on a '94 LT1?
This is the ground just above the Oil Filter on the driver's side, going into the engine block.
I'm trying to replace my negative battery cable - but am contemplating leaving well-enough alone on this one.
Old Aug 2, 2016 | 07:03 AM
WVZR-1's Avatar
WVZR-1
First hand experience NONE. BUT ..
I'd think 3/4 - I believe the bolt is 1/2-13 still and I doubt it a "reduced head" so I'd start there. Never done a - cable on an L98 or LT1/4, the LT5 is a Metric spec.
Old Aug 2, 2016 | 10:32 AM
383vett's Avatar
383vett
It is a 3/4" head. Should be able to access it with a box end wrench and/or a socket.
To Re: LT1 G104 Ground Socket Size?
