A/C Problem
Old Aug 2, 2016 | 09:20 PM
mvettewhite's Avatar
mvettewhite
Default A/C Problem
I have a 1996 W/Automatic Electronic Climate Control. AC works great when first getting into car when vehicle has not been used for that day. After driving for a half hour or so on very hot days and then shut the vehicle down for awhile, say for about 30 minutes or so and get back in. The inside blower fan come on but not the compressor or radiator fans. When car is driven home and every thing cools down, get back in it the next day, everything is fine again.
Any Ideas? Over charged, under charged Freon possibly/
Old Aug 2, 2016 | 11:32 PM
SELLC's Avatar
SELLC
I think I am having a similar problem with my 1996, except I have found that using defrost/floor, or just the recirculate button the AC works cold all the time.
If I try to switch to dash vents for AC it automatically turns off the AC for some reason, so I described my problem as AC only works in Defrost/Floor. The guys tell me there is a little module under the dash above the gas pedal that is known to have poor vacuum connectors. I haven't pulled mine out yet as I just got the car last week, but it sounds like where I'm going to start anyway.
Old Aug 3, 2016 | 08:59 AM
Kevova's Avatar
Kevova
If it is low on refrigerant compressor would cycle rapidly. Codes? there are several a/c related codes. When a/c compressor won't engage; if you jump cycling switch with cotter pin or paper clip will it engage? If not is 12v going to connector?
To A/C Problem
