89 Injectors
Old Aug 3, 2016 | 12:26 PM
p2vette's Avatar
p2vette
1st Gear
Default 89 Injectors
Needing to replace injectors on my 89. Weak starts. o-rings are visibly cracked, smell gas fumes under the hood, exhaust smells rich, the whole 9 yards. Anyway, any suggestions as to which would be best to use? I am looking on eBay and noticing a plethora of injectors for that motor with varying pressures. Im a noob to a lot of this and learning as I go so please keep that in mind. Thanks in advance.
Old Aug 3, 2016 | 04:51 PM
aklim's Avatar
aklim
Check with FIC what size injectors you have. If you have 24, THIS is a good way to go. Just have them clean and test it every few years. I do and there is always a loss of flow because of the crud buildup.
