Could this be a Temp. sending unit?
Old Aug 4, 2016 | 10:59 PM
tony58's Avatar
tony58
Default Could this be a Temp. sending unit?
LT1 engine.A/C works nine,car runs great.When I paper clip a & b ports both fans come on.Car never over heats,hardly ever over 200.
After car sits over nite engine cold.When I drive with AC off when engine reaches 180-195 AC cooling fan comes on and service engine lite comes on.
After car sits over nite engine cold. When I drive with AC on,blowing ice cold.AC cooling fan on from the get go.As soon as temp shows anywhere from 180-195 service engine lite comes on.
Does this sound like a bad Temp. sending unit causing the service engine lite to come on?
Old Aug 4, 2016 | 11:29 PM
aklim's Avatar
aklim
Sounds like you need a scanner to see why the CEL came on.
Old Aug 5, 2016 | 01:50 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Need to pull those codes. Fans shouldn't cause a CEL.
Old Aug 5, 2016 | 11:25 AM
JimLentz's Avatar
JimLentz
Just a shot in the dark, but seems your fans are coming on at too low of a temperature. Do you have a custom tune on the ECM that could be causing your issues? What year is it?
Old Aug 5, 2016 | 11:42 AM
JrRifleCoach
If his avatar is authentic, its a 96
Old Aug 5, 2016 | 12:15 PM
aklim's Avatar
aklim
Sounds to me like something happens when it goes into closed loop
Old Aug 5, 2016 | 01:22 PM
tony58's Avatar
tony58
Its a 1992.No custom tune.
Old Aug 5, 2016 | 01:28 PM
tony58's Avatar
tony58
Got two,92&96.Got to fix this lite from coming on,probably sell the 92.Wanting to get a 2017 Grand Sport.
Old Aug 5, 2016 | 01:33 PM
JimLentz's Avatar
JimLentz
Strange, as on my '92 the fans don't turn on until after 220 and the first time it happened I thought something was wrong with the car coming from a C3.
Old Aug 5, 2016 | 02:30 PM
aklim's Avatar
aklim
When we say it comes on at a given temperature that is too low or high, I like to see what the temperature is as reported by the sensor and scan the sensor with an infrared thermometer.
Old Aug 5, 2016 | 09:11 PM
tony58's Avatar
tony58
I thought the one on the drivers side,comes on when the AC is turned on?
To Could this be a Temp. sending unit?
