Hi Flow air filter
Old Aug 7, 2016 | 12:08 AM
Big Bird 88's Avatar
Big Bird 88
Default Hi Flow air filter
Is there any brand of performance or hi flow air filter for a 1988 C4 that does not require oiling?
Old Aug 7, 2016 | 12:10 PM
ChrisWhewell's Avatar
ChrisWhewell
I don't know. But I've heard that the ones you oil... some of the oil gets sucked into the intake and contacts the MAF sensor and does bad things, so I'm with you, to avoid those oiled ones. I'm using paper filters
Old Aug 7, 2016 | 02:44 PM
Big Bird 88
Yeah, trying to avoid that. I have never seen it but have only run one K&N in a land rover.
I am also wondering how does not oiling one of those filters affect its performance ?
Old Aug 7, 2016 | 05:39 PM
Dt86's Avatar
Dt86
It will if you over oil them. I've been running mine for 3 years and never had a problem. I probably just jinxed myself now haha.
Old Aug 8, 2016 | 09:24 AM
JimLentz's Avatar
JimLentz
They also don't work very well if you don't clean them. I recently purchased a '92 that is in very good shape except for a few odd things like the K&N filter looks like it hasn't been cleaned in forever. I put in a paper element.
Old Aug 8, 2016 | 10:34 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
The filter won't catch/capture much debris if it's not oil'ed. Dust will pass right through it.
Old Aug 8, 2016 | 12:58 PM
bac22's Avatar
bac22
Marketing 101...you might gain a couple of HP (under 5) if you're lucky, otherwise a high quality air filter is enough.
Old Aug 9, 2016 | 10:46 AM
jsmn4vu's Avatar
jsmn4vu
Once bought a car that had a K&N filter installed. Cleaned and re-oiled "by the book," then held it up to the light and could see pinholes. Replaced it with a good paper filter.
This has been discussed at length here -- great information in this post:
https://www.corvetteforum.com/forums...longevity.html
Old Aug 9, 2016 | 11:32 AM
sb66's Avatar
sb66
what about afe or aem - I think they have re-usable filters that do not require oiling - just can't remember if it is for our cars or not
Old Aug 9, 2016 | 12:57 PM
ToniJ1960's Avatar
ToniJ1960
I have an Accel Cool Blue, it has to be oiled when cleaned, but it was less expensive than a paper throw away filter.
Old Aug 9, 2016 | 01:12 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I wonder if a general consensus will ever be reached about this (K&N being good enough). Even *I* go back and forth.
Originally, I thought they're the best. Bought into the marketing hype; best flow, washable/reusable...
Then I read that they don't filter well. Seemed legitimate, so I got "scared" and thought that I shouldn't use one. They're no good.
Then I read elsewhere that they actually filter better, if oiled properly. So who knows? I don't.
But I know this; I have run a K&N in my truck, which sees all sorts of conditions, from clean air to desert, off road, work sites lots of towing/WOT for extended periods (lots of air flow through the filter and engine). The truck has had the same K&N filter in it since I bought it, with 82,000 miles. Truck now has 289,000 miles and the engine performs identical to the day I bought it.
Conclusion? If the K&N doesn't filter as good as other paper filters, then how good is good enough? Are paper filters filtering that which doesn't need filtering? IDK. Does the K&N provide any meaningful performance gain? I doubt it, but maybe. My take-away is that it probably doesn't matter, either way.
Old Aug 9, 2016 | 01:30 PM
jsmn4vu's Avatar
jsmn4vu
I don't claim to know, either, but an educated guess is that as soon as they get a little dirty, they filter quite well. But before that point, pretty sure they don't filter as well as paper (although they do flow better then).
Everyone understands the inverse relationship between effectiveness of filtration and ability to flow air, right?
Old Aug 9, 2016 | 01:43 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I do. Only way "around" increased filtration that I am aware of is more surface area. I agree that the dirtier a K&N is, better it filters...and the worse it flows.
Old Aug 9, 2016 | 02:21 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
.... My take-away is that it probably doesn't matter, either way.
If you over oil a reusable, it could be a problem. If you don't oil a reusable it could be a problem.
I suspect any performance difference is negligible.
The only advantage that I see is no replacement costs for a reusable, however that is consumed by time to clean and oil the filter and the cost of the cleaner and oil. So even "no replacement costs" or "lasts forever" is not really a benefit.
I have had several K&N, Blackwing, SLP, Vara Ram, reusable filters and they have worked ok for me, but I have never bought one. They came on cars that I bought.
So "My take-away is that it probably doesn't matter, either way."
To Hi Flow air filter
