O2 sensor good or bad?
Old Sep 12, 2002 | 01:09 AM
sinistervette's Avatar
sinistervette
Default O2 sensor good or bad?
Is it possible for the O2 sensor to be bad and not set a code? Is it possible to test O2 sensor? If so, how? TIA! :cheers:
Old Sep 12, 2002 | 01:10 AM
MrNuke's Avatar
MrNuke
Default Re: O2 sensor good or bad? (sinistervette)
Thats a DANM good question.
I'm runnig my original with 103K miles and wonder if I should swap it for a new one.. Is it easy or hard to do?
Old Sep 12, 2002 | 01:29 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I had a bad O2 sensor in my IROC that didn't set a code.
Jumper ALDL pins A&B, start the engine and watch the flashes of the SES light. After a minute of two the flashes should settle to about 1Hz. Then raise the idle to 2,000-2,500rpm and hold till for 30 sec.
In each case the SES flashes should be of equal On & Off duration. This indicates the ECM is in closed loop mode and the O2 sensor is fine.
Old Sep 12, 2002 | 01:49 AM
sinistervette
Default Re: O2 sensor good or bad? (65Z01)
Thanks 65Z01. :cheers: What exactly is "closed loop"/ "open loop"? I'm a carb guy, I know "closed hood"/"open hood" ! :lol:
Old Sep 12, 2002 | 02:09 AM
65Z01's Avatar
65Z01
When the engine is first stared and WOT operation it is in open loop mode. Here the ECM looks at all sensors EXCEPT the O2 sensor to determine air/fuel mix.
After the engine warms up, a fixed amount of time has elapsed, and the O2 sensor is OK the ECM enters closed loop mode and stays there during part throttle operation. During closed loop mode the ECM uses data from the O2 sensor to assure stoch air/fuel mix.
This is the main reason our EFI cars get such terrific gas mileage and still have great performance potential.
Old Sep 12, 2002 | 02:13 AM
sinistervette
65Z01, thanks again! :cheers:
Old Sep 12, 2002 | 11:02 AM
1SLO POK's Avatar
1SLO POK
I read on another forum you should change them about every 50k. Even if there is no trouble code. Reason being is that it takes a certain voltage to set the code, and just because there is no code does not mean your 02 is good. Main thing to look for is rough idling, and poor mileage. Personally on my 97 Suburban I will wait for the code. Cost per 02...$125.00 x 4....... :eek:
Old Sep 12, 2002 | 11:24 AM
JonM's Avatar
JonM
You can test an 02 with a volt meter and a torch...But an oscilloscope is idel.
http://www.wellsmfgcorp.com/counterp...erpoint2_3.pdf
Old Sep 12, 2002 | 12:25 PM
jtfrog's Avatar
jtfrog
Default Re: O2 sensor good or bad? (JonM)
Sometimes they just need to be cleaned. To do this unpluge a vacume line, a good one unplug would be the brake booster. Then reve the motor to 2000rpm for one minute and then plug the vacume line back on. It worked for me. Got this tip from an old machanic.
Old Sep 12, 2002 | 01:32 PM
VetBoy89's Avatar
VetBoy89
Ecklers sells a test tool for about $15.
I'm not sure about yours, but on my '89 the O2 sensor is only $25 so I replace it every 6 months with the fuel filter and plugs.
Just my .02 :rolleyes:
Old Sep 12, 2002 | 02:06 PM
jefft84's Avatar
jefft84
O2s can be moving back and forth from rich to lean but not be in the proper voltage range. The flashing light method will let you know its switching but will not let you know what ranges. General replacement is 30k for the single wire and 60-90k for the 3 and 4 wire heated sensors. Those milege guidlines are designed because your signal may be switching and not setting codes but may not be working through the full voltage range it is designed for.
To O2 sensor good or bad?
