Low Voltage at idle
Old Sep 12, 2002 | 06:20 AM
1SLO POK's Avatar
1SLO POK
Default Low Voltage at idle
When I first start my car my voltage reads 14.2, then after a few minutes or when the idle goes down to 600 rpm the voltage drops down to 12.0 and lower. But with just a slight increase of about 50 more rpms (650 rpm at idle) there is no problem.
I replaced the alternator and still the same problem. I even tried different size pully. Is there any way to adjust the idle, or is controlled by the computer? :confused:
Old Sep 12, 2002 | 09:11 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Low Voltage at idle (1SLO POK)
Mine did that and it was the battery
Old Sep 12, 2002 | 10:18 AM
Sharky Guam's Avatar
Sharky Guam
Default Re: Low Voltage at idle (ski_dwn_it)
Yup, change the battery....... :yesnod:
Old Sep 13, 2002 | 10:20 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Are you running under drive pulleys??????
tony :smash: :smash:
Old Sep 13, 2002 | 10:36 PM
MrNuke's Avatar
MrNuke
Default Re: Low Voltage at idle (oldace84)
Thats what I'm thinking.. I have that but it's the
pulleys that cause it..
Old Sep 13, 2002 | 11:04 PM
jfb's Avatar
jfb
600 rpm is too low for idle. Also, at this low an rpm, the alternator cannot generate high enough output voltage to charge the battery so the battery picks up the load and this is why you see such low voltage. Your idle speed needs to be set higher.
Old Sep 14, 2002 | 01:48 PM
1SLO POK's Avatar
1SLO POK
Default Re: Low Voltage at idle (jfb)
Yes, I do have the underdrive pulley. Is there anything I can do to raise the voltage and still keep the pulleys?
How do adjust the Idle for highher RPM. I thought the computer chip did the setting. I do have a after market chip.
[Modified by 1SLO POK, 5:52 PM 9/14/2002]
Old Sep 14, 2002 | 01:58 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
See if you can get an undersized alternator pulley.
You can get a chip programmed for a higher idle.
Old Sep 14, 2002 | 02:00 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
No problem, I had a similar symptom till I replaced my alternator and had the shop install the overdrive pulley onto the alt. Now I have 13.7 Vdc at cruise and 12.6 Vdc at idle of 600-700rpm.
The March P/N is #110 for the overdrive alt pulley; it's a 6-rib unit for '84-'87 Corvette. You can likely order it through Summit Racing.
This pulley matches up with the P/N 4101 underdrive crank pulley from the P/N 4435 Power & Amp Series pulley set from March. These pulleys are black power coated steel.
Tell the Tech at Summit that these are March numbers, not Summit ones.
1SLO POK's Avatar
1SLO POK
Default Re: Low Voltage at idle (PeteL)
So I take it that is the only possible way to raise the idle?
Old Sep 14, 2002 | 02:03 PM
1SLO POK's Avatar
1SLO POK
65ZO1,
I appreciate the info, I will give Summit a call. :)
Old Sep 14, 2002 | 07:54 PM
Rick Williams's Avatar
Rick Williams
Curious, but my car idles at 600 rpm with A/C on in drive and my voltage is fine..
Old Sep 20, 2002 | 03:32 AM
1SLO POK's Avatar
1SLO POK
Default Re: Low Voltage at idle (65Z01)
65Z01,
That was it! :D Voltage is at 13.2 at 600rpm. Im amazed on how small the pulley is.
Thank you for that info, you were a great help. :cheers:
Dean
[Modified by 1SLO POK, 11:39 PM 9/19/2002]
Old Sep 20, 2002 | 07:04 AM
blkmagik85's Avatar
blkmagik85
I remember when I had a voltmeter on my battery at idle showed 14.3 and the dash indicated 13.9... This was after I replaced the battery and alternator. I thought that when an engine is running the volt should be between 13.9 and 14.3?
To Low Voltage at idle
