disable vats 1996
Old Aug 10, 2016 | 08:19 PM
black96lt4c4's Avatar
black96lt4c4
Default disable vats 1996
I cant remember how to disable my system. I don't have a key fob.Please help
Old Aug 10, 2016 | 08:32 PM
WVZR-1's Avatar
WVZR-1
If you're only interested in the CRANK you just take the resistance value of the correct ignition key and insert a resistor with that value in the 2-wire connector at the base of the steering column.
DISABLE IN IT"S ENTIRETY substantially more difficult!
VATS has nothing to do with FOBs !!
Old Aug 10, 2016 | 08:42 PM
black96lt4c4
I have the keys, It wont crank after the kids messed with it.
Old Aug 10, 2016 | 08:58 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Is the security light flashing when you're trying to crank it?
What did the kids do to mess w/it?
Old Aug 10, 2016 | 09:00 PM
WVZR-1's Avatar
WVZR-1
Measure the key value at the key, then check at the connector at column base with key inserted in the cylinder. If the value matches then it ain't a VATS issue. If a VATS issue you can expect a dramatically different value at the column base. Do you have a second or more keys?
Old Aug 10, 2016 | 09:09 PM
antfarmer2's Avatar
antfarmer2
Dead or disconnected battery.
To disable vats 1996
