Wondering if 11×17 rear wheels will fit '92 C4
4th Gear
Hello Corvette Enthusiasts, anybody in the midwest knows that the Woodward Dream Cruise in Detroit is next week, and I wanted to dress my '92 6 speed for the occasiaon. I purchased new slotted and drilled rotors, ceramic pads, polished and painted the calipers white, and bought Nitto NT-555 Summer Tires to mount on New staggered Grand Sport Replica wheels. When painting the calipers today I noticed the new rear wheels come incredibly close to the inner wheel well. I am wondering if anybody is running Staggered (17×9.5F/17×11R) rims on their C4 and knows of this issue or has solved it with something such as wheel spacers. I was REALLY looking forward to the staggered rims but will exchange them before i mount the tires if I need to. Many thanks for any considerate relpies
Many use that wheel/tire combination on the rear - each install is/can be very different and may be different side to side. You need to measure and check each side but you can't check wheel/tire combination without the mounting. If you feel it's "incredibly close" wheel only it's going to diminish even more after the tire side-wall is added.
If you encounter issues a couple mm spacer might help but isn't generally required. Mount the tires, check clearances rotating by hand and rolling in driveway or parking lot, drive it making very tight turns and using the "rumble strip" on the side of the road exerciser the suspension. Remove tire/wheel and inspect for rubs then do what you must.
The rear wheel needs to be a 50mm offset, if a number larger or smaller than 50 then you've reason for concern and you need to STOP!!.
C4-RL (08-11-2016)
I'm running ZR-1-style wheels with 11x17 on the rear of my '93 and they fit but there is not a lot of clearance. I did have to slightly move the parking brake cable on the driver's side. The car is primarily for autocross use so the rear alignment includes more negative camber than the stock specs. This did provide for a little extra clearance at the outside top of the wheelwell.
My wheels are GM wheels from a '96 Grand Sport and have a 50mm offset. Tires are NITTO NT555 in 315/35-17.
Definitely do a test fit to make sure there won't be any interference!
C4-RL (08-11-2016)
4th Gear
A 1/2" spacer will use "ALL" of the hub and remove all of the hub-centric features that the OE fit offers. 3 - 5mm if needed max. If you have 50mm wheels there should be no issues.
So just to be clear, the OP's rear tires are 315s, right? Because if he is trying to shoehorn 335s onto those 11" wheels then there might be a clearance issue. But yeah, I run 17x11 et50 rims with 315 tires at all four corners of my 1996.
